Results 1 to 5 of 5
Thread: Notebook Screen
    Dec 2003
    Question Notebook Screen
    Hello Friends,
    I have a crashed Canon Notebook and I want to use his Screen on my Carputer PC.
    How can I transform the screen to put it in my default VGA output of the PC???
    And about his energy??
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    good luck doing it, not worth the hassle.
    Dec 2003
    Come on Everybody!
    Someone should have a project with this too.
    Jan 2004
    Washington, US
    The part that makes this so much more difficult than it may be worth is the LCD controller. Laptop LCDs aren't rigged to work simply once they've been removed from the laptop itself. They need an interface card in order to work with your VGA video card. LCD monitors that are meant for PCs already have this hardware installed.
    In order to use the LCD from your laptop, you'd need to find a suitable LCD controller board, which can be a serious pain and quite costly. I ended up spending more than I would on a 7-8" LCD VGA with touch-screen on just the LCD controller, which I then had to return due to a one-off versioning issue.
    If you want to give it a go, EarthLCD has quite a bit of information as well as some examples of the hardware you'll most likely need. If you go through with it, good luck!
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by Diogo.HUdson
    Come on Everybody!
    Come on you, read the FAQ :
  1. lillyput--all hype?----long review
    By liquid_smoke in forum LCD/Display
    Last Post: 11-21-2003, 11:44 AM
  2. notebook screen..
    By samc in forum LCD/Display
    Last Post: 03-14-2003, 09:51 AM
  3. use of TFT screen from a notebook ?
    By 8klepperke in forum LCD/Display
    Last Post: 02-12-2003, 10:23 PM
  4. Replies: 13
    Last Post: 07-02-2002, 11:54 AM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
