I assume that you are speaking of a flat panel.Originally Posted by ruflyf
the answer is yes and no.
If it is just the CCFL "bulb" then yes, you can pick up a comparable replacement at some electronics parts stores.
If your electronics, most likely the inverter board, are out, then it will be a little bit more work to find the correct replacement.
Either way, you will need to be savy with a screwdriver and a soldering iron!
-Mike
LinkBack URL
About LinkBacks
