Results 1 to 6 of 6
Thread: Lilliput and EPIA M1000 Look here
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Question Lilliput and EPIA M1000 Look here
    Hello, Sorry if there already exists a thread addressing this.
    I am curious to know if there is anyone that owns the Liliput 7" screen and the VIA M1000 Nehamiah that has successfully gotten theire onboard video card to output 800x480 (which is the liliputs native resolution). If so please share how you did this.
    Must a get PCI card that supports this? or is this possible with the onboard card?
    Newbie matqua's Avatar
    Dec 2003
    Australia
    There are people who have got it to work (I am not one of them) :-(
    Searching the forums should turn you up some good info.
    However, if the software you are using supports rescaling or whatever (like MediaCar or Media Engine) you can simply run 800x600 and tell it thats the screen res and it will scale everything for you so it looks ok.
    Its no fix but it gets you by!
    Matthew
    Mitsubishi Lancer Hatch
    VIA EPIA 800V
    128RAM - 10 GB HDD
    200 Watt PSU - 300 Watt Inverter
    Lilliput 7" Touchscreen
    D-Link USB FM Radio
    Dlink DWL-520+ b/g Wifi Card
    Fortuna GPSmart
    Alpine Amp and Splits
    Gentoo Linux/Windows 2000
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    There are many threads on this!
    Basically, something like Powerstrip doesn't allow you to choose custom resolutions on the Epia boards, simply because the onboard video doesn't support custom resolutions. WTG, Via!
    Many people (myself included) are using 800x600, and letting the screen adjust it to fit Get a skin for your favourite front end that is designed to be run 800x600 on a 16:9 screen, and everything will be right
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Dec 2003
    The best you can do is 848x480 or 720x480.
    I think it's more to do with the drivers not supporting custom resolutions rather than the hardware... with anyluck someone might comeup with a driver hack
    Jan 2004
    California
    Thanks for your thoughts. After some more research and more luck in finding the other threads I came to the same conclusion. The only way other people have gotten them to work is by strange and unusual methods.
    Quote Originally Posted by PCF_Ronin
    Jan 2004
    California
    I did notice that people with a previous version of the drivers has had some luck getting it to work. Is there a link somewhere or will some one make it available to download for us fellow lilliputers
    I think the version is 6.1.3.xxxx
  1. Rolling Verticle Waves in Lilliput VGA LCD
    By antimatter in forum LCD/Display
    Last Post: 01-26-2004, 08:28 PM
  2. Lilliput 7" VGA and EPIA M9000 issues...
    By heat in forum LCD/Display
    Last Post: 01-15-2004, 04:57 PM
  3. Lilliput 619GL-70NP and DigitalWW TM-710VGT
    By siren in forum LCD/Display
    Last Post: 01-14-2004, 02:30 PM
  4. FS: Complete CarPC with Lilliput Monitor
    By Krystos in forum Classified Archive
    Last Post: 12-23-2003, 04:43 PM
  5. Lilliput Issues - Help!!!
    By Falken in forum LCD/Display
    Last Post: 11-25-2003, 11:38 AM
