Results 1 to 9 of 9
Thread: why does everyone one use the lilliput monitors
    Newbie The Batfan's Avatar
    Jan 2004
    leesburg,fl
    I am in the process of my mp3 system the comp is made all now I have to do is decide on a screen, For the most part I see using a laptop tft screen with a digital to analog converter board is still cheaper and would give a better quality picture. you can buy a 10.4 tft lcd panel with inverter and all new for around 50 bucks on ebay, and get a convertor for 150-200 would the laptop screen not be a better choice or does the laptop not have the brightness and contrast for a indash installation.
    The Batfan
    amd 2500+
    200segate gb hd
    1 gig of 3200 DDr
    win xp antec
    550 power supply
    ati 9600 pro
    Still deciding on monitor but will prob use a 10.4 or 11" tft
    Oct 2003
    you can normally control brightness and contrast on a laptop screen via the controller, if the controller allows it, so if you buy a cheap screen and controller... your going to get what you pay for.
    As for the lilliputs... I love mine I bought the lilliput w/ touchscreen for $300 dollars from electronicar on ebay. He has great support too.,.. I just had a problem that I caused on my lilliput and he was willing to do anything he could to help me. He gave me a discount on the service payment. Luckily I found a great link on this site that helped me fix it myself.... but again the lilliput problem I had was completely my fault.
    Either way your going to pay about the same... the only difference is the lilliput you can control all of the brightness and contrast and everything... don't know about the laptop tft panel.
    New CarPC on the way again I think. I miss my old one!!!
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    its a size thing. and an ease thing, too.
    You buy a lilliput for $300 and it works. Most of us have cars, and a 7in screen is the best fit. Mine is EXACTLY the right size for my dash, and before I decided to hack up the casing and make the install look pretty, it sat perfectly where my 1.5 din radio would normally go, held in by friction.
    now, if you've got a truck with a lot of dash space, then a bigger screen would be good. I bought a 10.4 for my truck, but it was basically a giant lilliput--controller, screen, and touch kit all in one.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Low Bitrate BrUTaL's Avatar
    Dec 2003
    Guayaquil - Ecuador
    550W PS? I think that is too much, you don't need that much. Have you thought how you will turn on your PC and shutdown the carputer? I think you should take a look at the forums about Power Supplies.
    Jan 2004
    leesburg,fl
    Quote Originally Posted by BrUTaL
    I am going to build a relay I am a MECP certified master installer and did car stereos for 7 years, my truck is now controlled by a remote start system I am going to relay the computer into the system so I can start it by remote when the vehicle starts and also have a control panel to do it manually. far as the power supply I would rather have too much than not enuff
    Laterz
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    just completely unnecessary to have a 550W PS. To give you some perspective: I have a server with two motherboards, the first a tyan tinger MP running AMD MP 2000s, the second being an earlier ITX system, then 18 fans, a network switch, and 6 hard drives! All of that's running off of a 550W PS!!!!
    awgum. IMO max you would ever need is 200W.
    car computer rev 5: 8" lilliput and usual suspects
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    Quote Originally Posted by robiewp
    amen. People don't realize they are racking a hell of a power bill without using nearly all of what they are generating. power supplies are constant, so they output the rated power no matter what your usage is. complete waste imo. btw 18 fans and 6 drives.
    Apr 2003
    Quote Originally Posted by cdm
    That's not quite true. The rating for PC power supplies denote the MAXIMUM power that they can supply. The input power is proportional (but not linearly) to the output power consumed and depends on the efficiency which varies with load. You can verify this for yourself if you measure the input current with a multimeter.
    Feb 2004
    Same goes for any power supply. When you think about it, if it was to constantly produce 550W of power while switched on, even when nothing was connected to it, then it would have to dissipate a heck of a lot of heat!
    ..and, if it were true, fitting power saving light bulbs in your house wouldn't work..
  1. Lilliput install in and Impreza, Lilliput issues
    By SubPuter in forum LCD/Display
    Last Post: 04-19-2004, 09:56 PM
  2. Lilliput LCD monitors for UK customers
    By 001 in forum Classified Archive
    Last Post: 02-28-2004, 12:56 PM
  3. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  4. Lilliput Sources - USA
    By ukchris in forum LCD/Display
    Last Post: 11-22-2003, 05:42 AM
  5. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 03:46 PM
