Results 1 to 5 of 5
Thread: How bright is bright?
    Jan 2004
    Atlanta, GA
    Are you guys having any trouble seeing your screen in the daylight? What would be your minimum nit brightness recommendation for sunlight viewing?
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    250nits. 300 is better. 400 is whoa... anything above that might as well put a floodlight behind the screen. but your typical home lcd is 140-180 nits, just to give you an idea.
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    350 NITS measured through the touchscreen / whatever else. Lots of stats are misleading, giving the NITS from at the backlight
    car computer rev 5: 8" lilliput and usual suspects
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    The minimum brightness is going to depend on a few factors. Simply they are who, what, and where.
    Who is viewing it? What is acceptable to one person, may not be for the next.
    What are you viewing on it? Song lists on a dim monitor aren't quite as annoying as a DVD on a dim monitor.
    Where is it going? Since our monitors are in cars, they usually have some protection from direct sunlight. And some people take additional steps to shade them.
    Take a look at this FAQ.
    Nov 2003
    Marietta, GA
    RV,
    My Lilliput is much dimmer when it gets cold (sitting in the garage overnight). Also, the glare from the touchscreen makes the screen almost unuseable in some situations (see pictures HERE . My point is, nits are just one element of useability.
    MikeH
  1. Replies: 6
    Last Post: 01-19-2004, 04:33 PM
  2. Replies: 3
    Last Post: 01-18-2004, 07:37 PM
  3. Replies: 3
    Last Post: 12-24-2003, 05:30 PM
  4. no more bi***ing cops about your bright LCDs
    By carabuser in forum LCD/Display
    Last Post: 11-03-2003, 12:03 PM
  5. is 120nits bright enough
    By plaiming2 in forum LCD/Display
    Last Post: 02-18-2002, 08:12 AM
