Results 1 to 10 of 20
Thread: DIY Lcd has flicker....
    Jul 2003
    Earth
    Just plucked up the courage to wire up my DIY lcd!!
    Using up work time....i have a problem though the screen seems to work and it displays a picture but it seems to flicker or to be more precise it kind of slurs pixels.......sometimes it stops for a time if i hold it an angle, i was wondering if any one else had similar issues.....ive used the search feature and issues about grounding come up.....but i have it attached to a voltage regulator at work so im pretty sure its ok.
    This only happens on the vertical axis.
    Any help would be appreciated.
    Jun 2002
    Malaysia
    what brand of screen is this and what are you wiring it to?
    Jul 2003
    Earth
    Newbie neuroplague's Avatar
    Feb 2003
    Long Island, New York
    Are you sure the screen and controller board are compatable. The screen you are using is 6 bit and the controller document says its 24 bit. Also which ARV-300 series controller do you have. Is it arv-300 (vga), (svga), (xga1), or (xga2)?
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    I've been having this problem today... check and double check your connection between the controller and the LCD... I had a dodgy connection... and after playing with the wires, one eventually brokw. The LCD is now a lot more flickery, and I'm gonna have to rip the whole screen out the car to fix it..
    Jul 2003
    Earth
    Well i told this company what i had and asked them to supply me and they said it would be compatiable ...
    http://www.milesie.co.uk/
    So i put my faith with them really.
    My model is the svga version i believe
    Sorry to hear about your issue Mike i was concerned about my wiring and i have redone it but no difference happened.
    I have made progress though by turning one of the rotary switches on the back of the lcd....it gives me a solid pic now...but the picture is off the left of the screen and no matter how much i play with the osd it wont come back....
    anyone got any surgestions.
    thank you all for your help so far.
    Jul 2003
    Earth
    Can some one go to page 5 of this pdf and tell what SW5 does.....all i can tell is that does what i described above.....please please......
    pretty please.
    http://www.lcdspecifications.com/nec...448ac33-18.pdf
    Jul 2003
    Earth
    bump
    Feb 2003
    As far as I know the data enable pot has to do with the vertical and horizontal timing on the lcd timing contoller. This is factory preset and you probably shouldnt mess with it, unless it wasnt set according to the LCD specs.
    Jul 2003
    Earth
    aaah.....
    well i have contacted the people that sold me the controller....hopefully they maybe able to help.
    Are there any lcd experts out there?
  1. Help - Opinions on my DIY LCD case (single DIN)?
    By nxt125 in forum General Hardware Discussion
    Last Post: 04-14-2011, 09:28 AM
  2. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  3. lcd datasheet help
    By oddcomp in forum LCD/Display
    Last Post: 11-08-2002, 11:24 AM
  4. Replies: 5
    Last Post: 08-20-2002, 09:32 PM
  5. Got DIY serial LCD working
    By Machs_FueL in forum General Hardware Discussion
    Last Post: 05-21-2002, 11:41 PM
