I think you mean 640x480i. Maybe thats your problem.
I am using a PCI Nvidia Geforce 2 MX 100/200 and a Sony PSone LCD and i just got it to work right today. I used exactly Starfox's diagram to make a cable- the diagram you used. I used Mpro's way to set up timing in Powerstrip with the default 640x480i (Arcade) setting because I have a NTSC screen. My card does not have Csync but I tried it anyways because I have a Matrox G200 PCI in the mail that I think has Csync. Everything is not very sharp or clear but I think this is because I don't have Csync. When I first set it up I did the cable switch thing, but I can shutdown and restart and everything will work. Startup is messed up until Powerstrip loads. I have Powerstrip preferences Auto-load with Windows and Restore settings on Startup so that my settings are restored and the screen is normal. One problem I have is that when it first starts up or initializes the new settings the bottom of the screen is at the top and the top is at the bottom. I just go into Powerstrip Advanced Timing Options and use the up and down arrows of the set of four arrows on the right of Position and Size to fix it. I click once on the up arrow and the screen scrolls and click once on the down arrow to stop it. This may have to do with not having Csync. One other problem is that when I go full screen in a movie and then out the screen shifts down a little. After a while of doing this the screen is all messed up and I have to fix it in by continuing to go in and out of full screen or in Powerstrip.
Does anyone know how to fix my problems so I don't ever have to mess with settings? Does a Matrox G200 PCI have Csync?
I hope this helps a little therealeric.
LinkBack URL
About LinkBacks
