Results 1 to 10 of 15
Thread: mounting in a camaro
    Feb 2004
    Ohio
    hey i was gonna ask everyone else out there ... i notice when people mount they always angle it ... i was thinking of NOT doing that .... just keeping it flush ... so that way i could mount it inside where the stereo/hvac where.
    Does that work fine not angling it (cause in the camaro one does sit a LOT lower than most of your guys cars) or is it something u have to do?
    Anyone else mount in a camaro (its a 99 btw)
    1999 Camaro z28
    -- Computer installed :) Phase 1
    -- z28 302hp dynoed :( WAHH!!!!
    Constant Bitrate _maelstrom's Avatar
    Aug 2003
    WI
    What kind of screen are you thinking about getting?
    - Sony XAV-7W In-Dash 7" LCD
    - Via EPIA 800MHz
    - 256MB SDRAM
    - 40GB HDD
    - Targus Wireless Remote
    - Win 98SE
    See it Here
    or Here (cardomain.com)
    Feb 2004
    Ohio
    i was thinking of getting the Xenarc 700TS or TSV
    1999 Camaro z28
    Aug 2003
    WI
    I got this picture off cardomain. It's supposed to be the interior of 1999 Camaro. Is this what your's looks like? Where are you planning on relocating the HVAC controls to?
    - Via EPIA 800MHz
    - 256MB SDRAM
    - 40GB HDD
    - Win 98SE
    See it Here
    Feb 2004
    Ohio
    yeah, and well i was thinking moving the hvac to the glove box ... i eventually want to incorporate it into the carputer like that other guy did on here with his camaro.
    btw the width in there i 8.5" and 6.5" height (hvac and radio)
    1999 Camaro z28
    Feb 2004
    Ohio
    OR ... i was thinking to cut out that top part where it says camaro and has those two controls ... since those would be easy to move
    1999 Camaro z28
    Aug 2003
    WI
    The dimensions of the Xenarc screen are 7.75W x 4.75H x 1.38D. You'd have to measure to be sure, but I'm pretty posetive that removing the radio and the piece of trim between the radio slot and the HVAC controls will give you plenty of room for the screen. You'd just have to do some finishing work to make it look clean.
    As far as the glove box is concerned, that's actually where my computer is in my Camaro. It depends on what kind of hardware you're going to use, but the glove box is a pretty good spot to mount an Epia, HDD and some other hardware in a Camaro. You can see my install using the links in my signature.
    - Via EPIA 800MHz
    - 256MB SDRAM
    - 40GB HDD
    - Win 98SE
    See it Here
    Feb 2004
    Ohio
    cool ... thanks ... actually ... i was thinking of just putting the computer in the trunk on the left ... that part where u can fit a speaker.
    1999 Camaro z28
    Feb 2004
    Ohio
    Hey .... do u have any problems seeing the screen with the t-tops off?
    1999 Camaro z28
    Nov 2003
    no fair I want t-tops
  1. mounting a miniITX mobo
    By lummox in forum General Hardware Discussion
    Last Post: 02-11-2004, 04:27 PM
  2. Methods of mounting?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 10-01-2002, 05:40 PM
  3. Redant 7in LCD mounting questions
    By Birrman54 in forum LCD/Display
    Last Post: 04-03-2002, 05:19 AM
  4. car mounting kits
    By Shaggamuki in forum Off Topic
    Last Post: 09-19-2001, 06:49 PM
  5. Hard disk mounting - my thoughts
    By gizmomkr in forum General Hardware Discussion
    Last Post: 01-12-2001, 01:35 PM
