Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: lcd brightness modification?
  1. #11
    Dec 2003
    Quote Originally Posted by eCarô
    Any or all of the above, I'd say.
    I'm no expert, but as I understand it, the LCD has to have enough contrast ratio for the extra light. Too much light with a weak contrast ratio, and you can't display black anymore.
    that makes sense; if the light is too bright it will just shine through. i guess i will just a have to try it out.
    i am gonna buy an NEC NL6448AC33-29 10.4 lcd (i think). that lcd has a contrast ratio of 150:1. is that good?
    i am assuming that the higher the constrat ratio the blacker the black will be allowing me to increase the NIT output. does anybody know if 150:1 contrast ratio is high or low or normal? i have no other reference.
    eCarô do you know the constrast ratio of your allbright screen?
  2. #12
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    Quote Originally Posted by theomms
    150:1 is on the low end. Mine is 300:1. The highest I've seen (I think) was 500:1.
  3. #13
    May 2003
    SE Michigan
    My panel is the NEC NL8060BC26-17. You can find NEC specs here.
  4. #14
    Constant Bitrate kalito's Avatar
    Nov 2003
    ny
    if they jaus add more light!!! can we just do the same? we can contact one of those companies the make the gauges with the backlihjt ... and ask them if the can make one in a size of the screan and attach it to the back of the screan itseft... since it cames with a dimmer you can turn it up or down as desire.... possible or not possible?
  1. Replies: 10
    Last Post: 02-08-2004, 03:20 PM
  2. LCD Brightness Question nitts or cd/m2??
    By osirisdon in forum LCD/Display
    Last Post: 09-18-2003, 08:02 PM
  3. lcd brightness rating
    By apoc519 in forum LCD/Display
    Last Post: 04-28-2003, 02:49 PM
  4. lcd brightness question
    By plaiming2 in forum LCD/Display
    Last Post: 02-01-2002, 06:44 PM
  5. Sharp 6" LCD backlights are different brightness...
    By BluCivic93 in forum LCD/Display
    Last Post: 05-25-2001, 11:16 PM
