Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 66
Thread: Writeup Lilliput installation in TM-701L housing
  1. #11
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    yes it was a pita, however it was easier than trying to solder directly to the lilliput board where the switches connect, the freekin pins are so close together. i just didn't have the right tip for the soldering gun
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
  2. #12
    Jun 2002
    Malaysia
    Great writeup spyhunter.
    One question though, can you give a little more detail on that making the lilliput permanent on thing? Can you pretty back remove that thin PCB and just wire pins 5 and 8 together? I dont plan to use the IR and the other buttons.
    How do you wire the ribbon as you described? Or did you connect the ribbon to the connector, but you removed the connector from that tin PCB and wired the pins on the connector?
  3. #13
    Jul 2002
    central jersey
    Quote Originally Posted by masch
    i didn't do the permanent on thing, but you just jump the pins, see the wrx site.
    the ribbon from the lilliput to the control panel...i seperated each wire individually and solder that to another length i wire that i made which in turn was solder directly to the switches on the tm housing.
    Alex
  4. #14
    Constant Bitrate spectrrr's Avatar
    Jan 2004
    Dayton, OH / Cambridge, MA
    :::bookmarks:::
    figure i'll be at this stage in a few months..
    I for one would like to give a BIG thank you to spyhunter for taking to time to generate this writeup.
  5. #15
    Jul 2002
    central jersey
    welcome...the way i see it, on all of the car forums that i goto, there a billion writeups on everything from changing your oil to changing the motor. just my way of giving back.
    Alex
  6. #16
    Jun 2002
    Malaysia
    How do you separate the wires spyhunter? Its a bit risky no? How do I tell where I can cut and where I cant? I been to the WRX site but firstly the connector is laying on the side, while mine is standing up. Well that's no big deal but is there a way to check if pin 1 on the guide is the same side as mine? I guess that's when I need to take measurements with the multimeter eh?
    From the WRX site, I should cut on the white or the blue of the ribbon? And to short them out, gotta use a solder? isnt that a permanent solution? =) btw, those wires easy to solder? Because most wires i've come cross wont stick on the solder and I dont know why.
  7. #17
    Jun 2002
    Indiana
    If anyone wants to part with there lilliput front bezel or even the back would help me, please pm me, i am thinking of doing a install in my dash and need an experiment bezel.
    THanks.
  8. #18
    Jul 2002
    central jersey
    Masch i took a small knife and carefull seperated the individual wires from the ribbon. the blue part i just removed, its like a sticker. the wires themselves carry such a small current that risk of frying the whole thing is nil. use a multimeter to double check the connections and reference the stuff from the pictures. I had to rewire mine after i got it back together after i realized that i references from the wrong side.
    from there i just directly solder the (my wires) to the ribbon wires. its the pain in the *** getting a decent joint. thats part of the reason for the disclaimer and comments in the original post.
    Alex
  9. #19
    Aug 2003
    HOME CHICAGO, NOW IN Greensboro
    HI,
    A little off topic... I need the housing for the DWW-7VGA...
    If anyone has no need or wants to part with it please let me know
    Tnx
    ALIBABA - I30 99
    Nemiah M10000, C134
    DVD, 40Gig, 256MB DDR
    GPS, OBD 2, Reverse Cam
    Mute on stereo w I300 car kit
    Liliput 7in w usb touch screen
    Direct connect with BOSE-CD changer
  10. #20
    Jul 2002
    central jersey
    www.digitalww.com
    go there and buy it you thread hijacker :-P
    Alex
  1. indash housing and lilliput?
    By LudeAtude in forum General Hardware Discussion
    Last Post: 02-07-2004, 05:31 PM
  2. Calling all TM 701L users with GPS
    By fyleow in forum LCD/Display
    Last Post: 01-26-2004, 02:28 AM
  3. think this housing would hold the lilliput?
    By spyhunter in forum LCD/Display
    Last Post: 12-31-2003, 07:55 AM
  4. TM 701L Owners
    By chut in forum LCD/Display
    Last Post: 10-08-2003, 03:08 PM
