Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 66
Thread: Writeup Lilliput installation in TM-701L housing
  1. #21
    Aug 2003
    HOME CHICAGO, NOW IN Greensboro
    well that was not the intent ... but since I have been branded, well DWW dont have ..... so are you interested in sending me yours :-)
    and yes before I forget.... good write up
    ALIBABA - I30 99
    Nemiah M10000, C134
    DVD, 40Gig, 256MB DDR
    GPS, OBD 2, Reverse Cam
    Mute on stereo w I300 car kit
    Liliput 7in w usb touch screen
    Direct connect with BOSE-CD changer
  2. #22
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    thanks
    and oh yeah? whats this? lol http://www.digitalww.com/indashhousing.htm
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
  3. #23
    Aug 2003
    Thats what you put your lcd into ......I need the one from which your lcd came out ... like whats shown in your pic http://www.mattoree.com/z/lilliput/PICT0032.JPG and just the front bezel..... dont ask what happened to mine.. long story
    ALIBABA - I30 99
    Nemiah M10000, C134
  4. #24
    Nov 2003
    Southern California
    I'm having problems with my ribbon for the front panel buttons. I seperated the wires and tried soldering but I don't think they were all connected properly because I connected everything else, plugged in the power and pushed the power button and got nothing. Because a lot of the plastic got melted (also don't have the right soldering iron tip) I decided to cut off that end of the ribbon and 'restrip' it without even thinking. I assumed I could just gently cut on one side of the ribbon and peel it back exposing the wires but um... that's not working too well.
    Any suggestions?
    I'm sure I can play around with my knife a bit and scrape off the plastic but I'm just wondering if there's an easier way.
  5. #25
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    SoCal
    Quote Originally Posted by masch
    How do you separate the wires spyhunter? Its a bit risky no? How do I tell where I can cut and where I cant? I been to the WRX site but firstly the connector is laying on the side, while mine is standing up. Well that's no big deal but is there a way to check if pin 1 on the guide is the same side as mine? I guess that's when I need to take measurements with the multimeter eh?
    From the WRX site, I should cut on the white or the blue of the ribbon? And to short them out, gotta use a solder? isnt that a permanent solution? =) btw, those wires easy to solder? Because most wires i've come cross wont stick on the solder and I dont know why.
    I soldered a small length of wire (~1/2" long) of 30 AWG wire to the connector where it solders to the PCB. Not an easy thing to do unless you have a pencil point soldering iron and small diameter solder.
    I should have taken more photos...
    www.mechatroniks.com/wrx - Car PC Project/Dash Kits
  6. #26
    Jun 2002
    Malaysia
    spyhunter,
    How did you power up the lilliput? Did you cut the power connector along with the USB connector?
  7. #27
    Jul 2002
    central jersey
    umm if i recall correctly i took the usb like connector and used the supplied power adapter off of that. the cigarette lighter adapter that is...
    Alex
  8. #28
    Jun 2002
    Malaysia
    I understand you took out the usb like connector, but then, how did you use the supplied power adapter off that? Did you cut off the connector from the supplied power adapter too? Or did you solder them together?
  9. #29
    Jul 2002
    central jersey
    hmmm ok....the supplied cables that came with the lilliput answers all questions. the screen can be powered off of the jack right on the screen or though the usb like cable which has power, video and left/right audio jacks on it. i used the cig adapter, cut off the end and put a molex connector on it to power it off the psu. that answer the question?
    Alex
  10. #30
    Jun 2002
    Malaysia
    Okay, I think I know what you mean, its just that I didnt understand your original post in this much detail.
    It seems to me that you took out the Lilliput's USB-like connector off the board, and resoldered a USB extension cord with the 4 wires to where the Lilliput USB-like connector was.
    So now you have an extended USB-like connection to the board, I dont know how long but does it extend all the way towards the end of the case where the spring was? Or just a short distance?
    Assuming this is the case, you have 4 inputs now to the board,
    Pin 1 red
    Pin 2 White
    Pin 3 Green
    Pin 4 Black
    Ground to Ground
    or 5, including ground. Which of these pins do you connect to the +12V of your molex connector? Or do you straight away plug em in the USB port of your mobo (I understand USB connections has 12V out too right) and that's where you get the power to power the lilliput?
  1. indash housing and lilliput?
    By LudeAtude in forum General Hardware Discussion
    Last Post: 02-07-2004, 05:31 PM
  2. Calling all TM 701L users with GPS
    By fyleow in forum LCD/Display
    Last Post: 01-26-2004, 02:28 AM
  3. think this housing would hold the lilliput?
    By spyhunter in forum LCD/Display
    Last Post: 12-31-2003, 07:55 AM
  4. TM 701L Owners
    By chut in forum LCD/Display
    Last Post: 10-08-2003, 03:08 PM
