Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 66
Thread: Writeup Lilliput installation in TM-701L housing
  1. #51
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    thanks fella.. I didnt get one of these leads in the box with mine.. maybe its worth running a wider ribbon cable down, to include v1/v2 inputs.. might be a idea..
    checked out the link, looks good, would only need to add some more wires to the ribbon cable to include these.. 2 infact if i'm not going to fit the speaker.. As the header sockets are 14 pins anyway.. then thats it.. :-)
    thanks for the info m8..
  2. #52
    Feb 2004
    Manchester
    ok been doing alittle tracing, and have come up with some alternative points to solder for the buttons
    its 60k, so will just stick a link, otherwise it my slow your viewing pleasure of these forums ;-)
    Click HERE
    now I havent tried these yet.. SO BE WARNED..
    soon as my housing comes I will let you know
  3. #53
    Apr 2003
    Quote Originally Posted by CdRsKuLL
    I just tried using a 10 wire ribbon cable to carry the VGA + USB touchscreen controller signals and ran into problems. The cable is too stiff - when you try to out the monitor back into the housing, the cable bunches up and prevents the monitor from latching into the housing. I guess that's why the housing uses a flex cable instead. I'm going to try using a spare 13 wire flex cable from my junkbox to see if this works better.
  4. #54
    Feb 2004
    Manchester
    ok, I dont know how your putting your ribbon cable in the housing, and I havent got mine as yet to try, but if you mounted the wire vertical I would of thought it would have more room to coil up, rather than mounting it horizontal. just a idea.
  5. #55
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    Excellent job! I wish I had this info when I did mine. But it's done now, I kinda skipped over the switches but I may take it apart and do those this weekend, or next, I'm not in any hurry. I am not looking forward to de-soldering the PCB that is currently connected to the switches....i guess you did that also?
    Peter
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
  6. #56
    Apr 2003
    I found out that problem latching the monitor was caused by the power/V1/V2 cable. It was protruding a tad too much from the backplate and prevented the monitor from moving back the 1/8" or so needed to unlatch it. The ribbon cable works fine now, mounting it vertical is a good idea. I spliced the ribbon cable to the VGA/touch cable (the one soldered to the Lilliput) so I can use the original VGA/touch extension cable (the one going to the PC).
  7. #57
    Apr 2003
    Quote Originally Posted by chut
    Peter
    This part isn't too hard - with the excellent photo from CdRsKuLL, it's even easier since the solder points are spaced far apart. There's no need to desolder or remove the 8-pin connector on the switch PCB - just solder the 8 wires directly to the corresponding points on the component/switch side of the board.
    I did have problems getting the IR sensor to work after I transplanted it to the new switch PCB. I don't really need the remote anyway so it doesn't bother me.
  8. #58
    Feb 2004
    Manchester
    ok peeps.. nearly finished my lilliput conversion.. just waiting for a replacment touch screen... dam them cracks.. read about it on my site.. let me know what you think
    CdR
  9. #59
    Jun 2002
    Malaysia
    CdR
    Great site cdrskull. Too bad I finished my installation somewhat. Just maybe I'll add the infrared later. Right now all I've connected was the power connector and that was tough as hell. Maybe with your diagrams it could have been easier.
    What's lacking on your site is how you connected the other end of your ribbon cable, the one with the VGA. Because using ribbon cables would be much easier to close the panel.
    Where are you getting the replacement touchscreen from? any links?
  10. #60
    Feb 2004
    Manchester
    hi fella, I'm going to redo afew things when my touchpanel comes.. I decided I had two choices. Either buy another lilliput HERE (195 all in) or buy another touchscreen from Digitalww ($100+$20 postage + 21 import tax= 100). I decided to buy another lilliput, I know this is a bit extreme, but as its only the touchscreen I need, the lilliput would still be working.. so 1. I have loads of spare parts, 2. A working second monitor for future projects ? who knows..
    The power,v1/v2 cable I've used I will grab a picture of that for you. I will also be changing the connections inside prob going to solder a 10 wire ribbon cable direct to the pcb rather than have that connection.. this then will allow me to use the din connection on the back of the unit. Even with the 14 wire cable it does shut easy, infact one handed is no prob's.
    I got a bit dishearted when my screen cracked.. gutted infact. I even had one of them moments when jumping on the housing was a good option.. I didnt luckly enough.. went and had a smoke instead.. Anyway.. should be only afew days for the new screen to come... will update my site then.
    cheers
    CdR
  1. indash housing and lilliput?
    By LudeAtude in forum General Hardware Discussion
    Last Post: 02-07-2004, 04:31 PM
  2. Calling all TM 701L users with GPS
    By fyleow in forum LCD/Display
    Last Post: 01-26-2004, 01:28 AM
  3. think this housing would hold the lilliput?
    By spyhunter in forum LCD/Display
    Last Post: 12-31-2003, 06:55 AM
  4. TM 701L Owners
    By chut in forum LCD/Display
    Last Post: 10-08-2003, 02:08 PM
