Page 1 of 7 1234567 LastLast
Results 1 to 10 of 66
Thread: Writeup Lilliput installation in TM-701L housing
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    Disclaimer: DO NOT TRY THIS...meaning I will not help anymore than this post. If you have never soldered something before, forget about it. If you have never worked on a breadboard before, its not that bad. I claim no responsiblities nor does this site or anyone else here in case the reader of the post f-s up their screen or housing.
    Parts Required:
    1 Lilliput (pref vga with touch or else this is pointless. I got mine on the group by (try searching if you're interested).
    1 TM-701L housing which you can get http://www.digitalww.com/indashhousing.htmhere
    1 Package of small tie wraps, you'll need a bit cause its a lot of trail and error
    Electrical Tape
    Solder
    Small guage wire
    One USB extension cord
    Tools Required:
    Soldering iron, I did mine with a 35watt gun, it will be easier with a small tip and lower wattage gun, but no biggie if you don't have it.
    Pair of needle nose and cutting plyers
    Power drill with a 3/16 or so drill bit
    Screw Drivers, long and skinny.
    Digital Multimeter
    Timing Required: hmm 4 hours or so.
    Prelude, if you want to save money than this is the way to go, else just get Armen's preassembled kit, easier and takes less time. Plus you can yell at him when it doesn't work and not yourself or me or this guide
    Reference Links:
    WRX Car Computer Project - http://www.tmz.com/wrx/lilliputLCD.html
    Armen's site - http://www.digitalww.com
    Lilliput posts with Pin info- has anbody got there in-dash housing
    http://cs-people.bu.edu/dima/photos/liliput/
    http://www.digitalww.com/VGA_Controller_howto.htm
    Here we go...
    READ everything before attempting please.
    1) Disassembly the lilliput, see Armen and WRX site for more info. Pretty much just take out the screws. I had to cut part of the housing to get the wiring out of it. Be careful not to pull too hard on anything wire-wise, if you break something you're up the creek. There are three (3) connectors from the circuit board to the lcd. http://www.mattoree.com/z/lilliput/PICT0032.JPGPicture
    2) Once the screen is out of the housing, also remove the control panel up front. Using the solding iron, take out the ir receiver from the lilliput control panel. its the little black thing with three connectors. Don't break it!
    3) Take your housing and remove the back panel, four screws. There are a bunch of other little brackets and whatnot holding the ribbons and such together, remove them, you won't need them anytime soon.http://www.mattoree.com/z/lilliput/PICT0034.JPGPicture
    4) Take out the sliding cartiage from the housing and open the part where the lcd goes, if you haven't already that is. You'll want to cut a hole about where it is circled in purple. this is for the wires that will come out of the housing.
    5) Inside the TM housing where the lcd goes, on the side with the window, there are two plastic clippy things on the top, cut'em both off and shave it down as best as you can. In purple again http://www.mattoree.com/z/lilliput/PICT0041.JPGPicture
    6) Take out the button breadboard on the TM housing, four screws. Now somewhat the tough part. The easier path to go is to take the board from the TM housing and simply solder wires onto eash switch so that the wires may be spliced into the wiring from the lilliput. http://www.digitalww.com/VGA_Controller_howto.htm <-Pics here
    7) Using the info from the WRX site and the post i've linked above, connect all the appropriate pins from the lilliput's cable to the TM board. For the ir receiver (which i think is the most important) i simply took off the one from the TM housing and put the Lilliputs there. They are different! and cannot be interchanged as far as i know.
    8) Double check all the connections and cover appropriately with tape. Use a multimeter to be sure everything is correct. Test the screen to make sure it turns on and the buttons/remote works. Next take that little usb looking connector off the lilliput off. yup completely remove it. Take your usb cord and cut it in half, seperate the wires including the ground and reconnect them to the lilliput's board. In red http://www.mattoree.com/z/lilliput/PICT0041.JPGPicture
    Pin 1 red
    Pin 2 White
    Pin 3 Green
    Pin 4 Black
    Ground to Ground
    9) cover everything in tape or whatever you prefer. test fit the screen and make sure everything fits ok. I used some pieces of that usb cable to wedge in there to make it sit correctly and center. once thats done, feed the wires through the hole we made eariler and close the unit, use two screws from the liliput if your housing didn't come with any.
    10) By far the most pain the *** part is next. getting the damn thing to close. You're gonna want to drill two sets of holes towards the rear of the housing on the bottom, where the wires will eventual come out. one right on the hole, the other set about 2.5 inches down.
    11) Look at this picture and see how the wire is ran for the vga/touch signal. it was the pain in the rear to get it in there, i had to remove every screw i could and then that the damn thing was glued in there. The clear plastic part is what i'm referring to. Tie wraps are your friend from here on out.
    http://www.mattoree.com/z/lilliput/PICT0048.JPGPicture
    12) Refer to Armen's guide for the rest. its pretty straightforward. http://www.digitalww.com/VGA_Controller_howto.htm[/url]
    here are the rest of the pictures
    http://www.mattoree.com/z/lilliput/PICT0031.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0033.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0035.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0036.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0037.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0038.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0039.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0040.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0042.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0043.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0044.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0045.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0046.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0047.JPGPicture
    http://www.mattoree.com/z/lilliput/PICT0049.JPGWARNING ADULT CONTENT...i couldn't find a better way to test the screen
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Bad urls for the pictures.. missing .jpg I think
    Brave
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Apr 2003
    spyhunter - thanks for the writeup. Is there any way to re-use some of the cables provided with the in-dash housing ? I'm having some problems with the Lilliput 9-pin DIN connector and would like to avoid using it if possible - the image sometimes gets blurred and I have to twiddle with the connector to get it back.
    Armen - if you are reading this, please let me know how my order for the in-dash housing is going !
    Low Bitrate BrUTaL's Avatar
    Dec 2003
    Guayaquil - Ecuador
    Hahahaha PICT0049.JPG.....nice way to test your new install!
    Thanks for the guide and pictures, it helps a lot! If people have problems opening the links or pictures, one way is to go to: http://www.mattoree.com/z/lilliput/
    Then click on each file, there you can see all the pictures available.
    Jul 2002
    central jersey
    links are fixed. i used none of the cables provided with the housing. only the cables that came with the lilliput and that extra usb cable are required
    Brutal:
    Alex
    LAME :) lopan's Avatar
    Dec 2003
    Clarksville TN
    Did you find anyplace to hardwire the power connector? I tested the solder points underneath the power connector on the board but I'm reading continuity on all four pads... I kind of don't wanna fry my lilliput, any ideas how to hardwire power to this thing?
    ....Edited to not look like such a newb....
    Jul 2002
    central jersey
    good job quoting the whole message :-P
    hardwire what power connector? the switch that turns the lilliput on? see the WRX liliput page i think it was pins 5 and 8. or are you referring to the usb like connector, or the 12v adapter directly on the board? i just did the usb thing and ran it that way. i saw it as the easier way to go.
    Alex
    Dec 2003
    Clarksville TN
    [QUOTE=spyhunter]good job quoting the whole message :-P
    Yeah sorry bout that, still getting used to the board and all... Actually no, I was talking about where the barrel connector plugs in, I worked around it.
    I opened up the lilliput and somehow during the install broke the little barrel connector receptacle thingie (sorry lack of better words). Anyway ended up just finding two good solder points that still worked, reinforced the broken plastic with epoxy and went on.
    Jul 2002
    central jersey
    good to see that my efforts aren't in vain, good luck with the rest, its cake from there.
    Alex
    Dec 2003
    Clarksville TN
    The writeup was EXTREMELY helpful, thanks... anyway here is the link with my new install. BTW ya didn't have to hack up your case, took all of five minutes to de-solder and resolder the wires to let the cable slide out I know it had to have been easier then soldering those ribbon cables... I bet that was a pain!
    http://www.mp3car.com/vbulletin/show...023#post164023
  1. indash housing and lilliput?
    By LudeAtude in forum General Hardware Discussion
    Last Post: 02-07-2004, 05:31 PM
  2. Calling all TM 701L users with GPS
    By fyleow in forum LCD/Display
    Last Post: 01-26-2004, 02:28 AM
  3. think this housing would hold the lilliput?
    By spyhunter in forum LCD/Display
    Last Post: 12-31-2003, 07:55 AM
  4. TM 701L Owners
    By chut in forum LCD/Display
    Last Post: 10-08-2003, 03:08 PM
