Results 1 to 5 of 5
Thread: Question about 75Ohm cables...
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Question Question about 75Ohm cables...
    I have a Radeon 7500 in the carputer. I have issues with getting the TV out function to work properly. It refuses to boot with the LCD connected VIA the compsite out. (really S-Video to composite adaptor that came with the video card). I can use a monitor just fine and force the TV out but when I reboot the puter does not see/use the LCD.
    I've tried plugging the puter into my family room TV, which it sees, then switching it over to the LCD which will work, BUT if I turn the puter off for a minute and turn it back on the same thing, no LCD out.
    I even bought this cable: http://www.bestbuy.com/site/olspage....0&type=product which claims "Dielectric insulation maintains 75 ohm signal integrity". I thought this would give it the 75 Ohm load needed for the video card to recognize the LCD but it still does not work.
    I have searched the forums and found this thread: I'm an idiot which originally had a picture showing how to splice a 75Ohm resistor into a composite cable, posted by ODYSSEY, but it does not display anymore. Should I have to do this even though the cable claims 75 Ohms?
    Any Ideas anyone?
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Jul 2000
    Orlando, FL
    The 75 Ohm rating of the cable does not refer to it's resistance between the center conductor and the shield. It refers to the impedance of the cable, based on certian factors. If you're curious, I found this page:
    http://www.epanorama.net/documents/w...impedance.html
    Maximum Bitrate none's Avatar
    Sep 2003
    Try looking for an answer at an ATI-specific forum, I bet there's a registry hack or something to force tv-out.
    Jan 2003
    Ruston, LA
    Code:
    -----------------------------------------------Center
                            [ ] 75Ohm resistor
    -----------------------------------------------Shield
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    The newer ATi Catalyst drivers let you override TV detection, i've had to use that myself to make my R9000 display something on my TV at home.
    TV out not detecting a TV is quite common with ATi cards due to people munging up the specification for termination and detection when they design TVs...
  1. Replies: 5
    Last Post: 02-02-2004, 10:52 PM
  2. Where to get long high quality VGA cables....
    By psyclobe in forum General Hardware Discussion
    Last Post: 10-22-2003, 02:07 AM
  3. usb question?
    By cubanmoses in forum General Hardware Discussion
    Last Post: 07-25-2003, 01:27 AM
  4. 2 pin jumper cables?
    By zootjeff in forum Power Supplies
    Last Post: 02-13-2003, 06:10 AM
  5. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 01:27 PM
