Results 1 to 10 of 17
Thread: Hacking my Morotized screen.
    Mar 2003
    WVA
    Ok so I have this screen:
    I want to turn it into a VGA screen. So all I need is a VGA controller? Correct?
    I already took it apart and it has the same Panasonic LCD Module that Armen sells. But do I need an Inverter or anything else?
    Also what would be a good LCD Controller solution? I cant seem to find one via google.
    Click Here to see my Car's Website
    2003 Nissan Sentra Spec-V
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    What LCD panel is inside? Can you take pictures of all the components?
    If it is the same LCD Panel than the Gain/Xenarc controller and inverter will work.
    What about the electronics that control the motors? Are they on the main Video controller or on a separate circuit?
    Let me know.
    Armen
    Quote Originally Posted by Spec-V
    Mar 2003
    WVA
    Quote Originally Posted by digitalww
    Let me know.
    Armen
    Electronics for the motors are on a seperate circuit. The LCD Panel is identicle to the one in this pic:
    Thanks for any help Armen.
    Greg
    Sep 2002
    ILLINOIS
    Then the controller (xenarc/gain) will work. If you take your LCD panel and the controller out of the housing, does it still slide in and out?
    This could be a very simple mod. Just have to try. The controller will definitely work. Also you will need to figure out how to run the VGA cable.
    Can you get any pictures?
    Armen
    Mar 2003
    WVA
    I'm at work now. I will try to post some pics tonight.
    Will I still need an inverter? I never understood exactly what they do anyway.
    Also how much is the xenarc/gain controller?
    Newbie Rev_BoB's Avatar
    Feb 2004
    backlighting
    is what the inverter is for, don't know why you need one though
    As Saddam once said.."COME ON!!!"
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    the backlight are using CCFLs, and they run on high freq AC generated from the inverters
    with no inverters you have no light and can see nothing.
    -Mars
    Feb 2004
    as you can see from the picture
    it already has backlighting unless I'm missing something here.
    Sep 2002
    ILLINOIS
    The backlight still needs an inverter to power it.
    Armen
    Quote Originally Posted by Rev_BoB
    Sep 2002
    ILLINOIS
    You will need an inverter ($10), VGA Controller and Cable ($160).
    Take some pics of the mechanism if you can and every other angle inside the housing.
    Armen
  1. Replies: 21
    Last Post: 08-27-2006, 02:26 AM
  2. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 07:38 AM
  3. lillyput--all hype?----long review
    By liquid_smoke in forum LCD/Display
    Last Post: 11-21-2003, 11:44 AM
  4. Replies: 13
    Last Post: 07-02-2002, 11:54 AM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
