Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Perfect 7" widescreen LCD?
  1. #11
    Feb 2004
    I sent an e-mail to Earth LCD inquiring about availability and pricing.
    I have no idea on pricing as of yet, but my guess would be in the several hundred-dollar range ($300-500).
    Anyhow, that's only a guess.
  2. #12
    Constant Bitrate slffl's Avatar
    Jan 2004
    Nice, I'm hoping some other alternatives to the Xenarc and Lilliputs will come out soon.
  3. #13
    Feb 2004
    Quote Originally Posted by slffl
    Keep in mind, these are bare LCD's, not packaged LCD's like the Xenarcs or Liliputs..
    "Some Assembly Required" is the phrase.
    May or may not come with controller cards, inverters, power supply or cables...
  4. #14
    Feb 2004
    More 800x480 16:9 LCD's
    A few more part numbers for other widescreen LCD's with similar specs:
    Brand AU Optronics
    Part Number A070VW01
    Size (in.) 7.00
    LCD Type TFT
    Resolution 800X480
    cd/m² 400
    http://www.auo.com/english/products/...&product_id=50
    Brand Hitachi
    Part Number TX18D11VM1CAA
    Size (in.) 7.00
    LCD Type TFT
    Resolution 800X480
    cd/m² 400
    http://www.japantft.com/products/Hit...8D11VM1CAA.htm
    http://www.hitachi-displays.com/catalog/skg-228-e.html
    Brand Hitachi
    Part Number TX18D16VM1CAA
    Size (in.) 7.00
    LCD Type TFT
    Resolution 800X480
    Other
    cd/m² 350
    http://www.hitachi-displays.com/cata...6VM1CAA-e.html
    Brand Hitachi
    Part Number TX20D16VM2BAA
    Size (in.) 8.00
    LCD Type TFT
    Active Area 174.0(H) x 104.4(V)
    Resolution 800X480
    http://www.hitachi-displays.com/cata...6VM2BAA-e.html
    (PDF) http://hitachi-displays-eu.com/menu/brochure1103.pdf
    Brand Hitachi
    Part Number TX20D16VM1CAA
    Size (in.) 8.00
    LCD Type TFT
    Resolution 800X480
    Active Area 174.0(H) x 104.4(V) mm
    cd/m² 400
    Pay special attention to this last two LCDs - the Hitachi 8" TX20D16VM2BAA /TX20D16VM1CAA.
    The active area dimensions are EXACTLY the same size as a WRX's double-din opening! The double-din opening measures 174mm wide, and 100mm tall.
    These are all new-model LCD's however, so availability might take a while.
    The second Hitachi 8" LCD is listed as being "in development".
    Also, the interfaces are listed as "C-MOS 6-bit Digital RGB", so I'm not sure if that's LVDS or requires a controller.. but 6 bits x 3 (RGB) is 18-bits, so it might be LVDS.
    Edit: I sent an e-mail to Japan-TFT.com about the Hitachi 8" TX20D16VM2BAA LCD.
  5. #15
    Feb 2004
    LVDS / CMOS Interfaces...
    This post is primarily for my own reference, but thought others might find it interesting.
    I've been looking for an LCD with an LVDS interface, so I can hook it up directly to a board like this, which has a LVDS transmitter.
    http://www.commell-sys.com/Product/SBC/LV-671.HTM
    Problem is, the Hitachi 8" ones above are CMOS interface, not LVDS.
    Normally, this requires an expensive LVDS receiver.. but all it really is is a single chip, like this:
    http://www.national.com/ds/DS/DS90CF561.pdf
    The application diagram on the first page is interesting, but the rest is mostly technical.
    Edit: The receiver chip is self-contained, no external support chips required, and is Only $7 for one.
    References:
    http://www.digikey.com/scripts/dksea...D%2DND&site=us
    http://www.national.com/pf/DS/DS90CF364A.html
    Now, I have some electronics engineering experience, so I figure it probably wouldn't be too hard to design a small LVDS receiver module for CMOS LCD's like this.
    And with PCB production services like this, it wouldn't be too expensive:
    http://www.expresspcb.com/ExpressPCB...sMiniboard.htm
    The boards themselves would probably be only around $20, and with the parts, maybe $40-50.
    Just some random thoughts.
  6. #16
    Dec 2003
    if you can get it to work I'll definately buy4
  7. #17
    Feb 2004
    Actually.. I may not even have to make the converter.
    This'll do it:
    http://www.evalue-tech.com/evalueweb...mn=EPM-1530-18
    PDF: http://www.evalue-tech.com/Download/...t/EPM-1530.pdf
    Picture: http://www.evalue-tech.com/evalueweb...1530-18-72.jpg
    Listed here, along with 18-bit and 24-bit transmitter/receiver modules:
    http://www.evalue-tech.com/evalueweb..._line.cfm?pt=7
    Things I've noticed:
    • It runs on 5v or 12v power feeds. Easy connection to a PC power supply, they've even got the pin-holes for the floppy-drive size connector. Edit: The receiver does not need a power feed - the transmitter boards do, and have the floppy drive connector for power.
    • The Hirose connector DF14A-20P-1.25H at the top of the pic is the exact same kind as on the Commell LV-671/LV-670 LVDS transmitter. Edit: Hirose connector at the top is the TTL/CMOS output - LVDS input is the connectors at the bottom, either one.
    • With a board this small, I can't imagine it costing very much.
    Of course, the company's not in the states... I'll ask them about pricing anyway.
    Edit: They have a US distributor: http://www.bcmcom.com/
    I'm going to ask them about pricing and availability for this.
    This would be useful for anybody that picks up any LCD with a CMOS/TTL interface.
  8. #18
    Feb 2004
    Some more spec sheets for the 8" Hitachi TX20D16VM2BAA:
    Spec Sheet w/Pinouts:
    http://hitachi-displays-eu.com/pdf/tx20d16vm2baa.pdf
    Inverters:
    INVC617
    http://hitachi-displays-eu.com/pdf/invc617.pdf
    INVC657
    http://hitachi-displays-eu.com/pdf/invc657.pdf
  9. #19
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    subscribing to interesting thread...
  10. #20
    Feb 2004
    Hm, this thread looks like it has the potential to answer all of my LCD questions...
  1. EPIA on board gfx + 7" widescreen LCD = problem?
    By phoTToniq in forum General Hardware Discussion
    Last Post: 06-23-2004, 08:12 PM
  2. GPS on 7" widescreen lcd
    By Nicholasp27 in forum LCD/Display
    Last Post: 03-04-2003, 08:54 PM
  3. Getting computer display correct on 7" widescreen
    Last Post: 02-09-2003, 07:24 PM
  4. 7" Widescreen VGA LCD for $499!?
    By kgoode80 in forum LCD/Display
    Last Post: 07-07-2002, 07:31 PM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
