Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 74
Thread: what video cards support 848x480 res??
  1. #21
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    Quote Originally Posted by NotchbackVW
    How do you create a 'custom' resolution? I have a GeForce 2 and want to run 848x 480 on my lilliput. Its not listed in the list all modes. Thanks.
    Isn't 848x480 already there?
    You may have to uncheck the "Hide the modes that my screen can't display."
  2. #22
    May 2003
    SE Michigan
    Try this:
    Right-click on desktop and select Properties
    On the Settings Tab, click Advanced
    On the Adapter Tab, click List All Modes
  3. #23
    Nov 2003
    You can get the proper widescreen display with the onboard video on the M10000, however, it looks like crap. You can barely read the text. DVD is fine though. So I suggest just living with 800x600 in distorted mode since it aint all that bad, then switch to the widescreen resolution when viewing DVDs.
  4. #24
    Constant Bitrate NotchbackVW's Avatar
    Jan 2004
    UK
    No it wasnt, but gonna try the latest Nvidea drivers and see if it appears. Done more reading on here and it seems all Geforces are indeed capable without to much bother, so hopefully new drivers will help.
    Thanks.
    Quote Originally Posted by eCar™
  5. #25
    May 2003
    SE Michigan
    No it wasnt...
    Where were you looking? In "List All Modes" like in my last post?
    And what driver version are you using?
  6. #26
    zvi
    zvi is offline
    Constant Bitrate zvi's Avatar
    Jan 2004
    Tbilisi, Georgia
    Quote Originally Posted by afr0puff
    can you teach us how to set widescreen resolution on onboard VGA?
    '93 Opel Vectra A with Custom Dash with 7" lilliput
    VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
    http://zvi.home.ge/pics/?dir=vextra
  7. #27
    Jan 2004
    UK
    Yep in list all modes. Not sure what drivers, if any, think XP just found it. will try putting drivers on! thats probably my problem. How dumb of me.
  8. #28
    May 2003
    SE Michigan
    Wait. Stop.
    If you are truly still running Windows drivers, you may want to try something...
    First check your driver version by:
    On the Adapter Tab, click Properties
    On the Driver Tab is the driver you are using.
    If you are using a Windows driver, and want to see how much performance you've been losing, benchmark it. You can get a free graphics benchmark called 3dMark by Futuremark (formerly Mad Onion). It will demonstrate what you've been missing.
  9. #29
    Jan 2004
    UK
    OK cheers, wasnt using windows drivers on 'purpose' just kinda forgot that I reinstalled windows a few weeks ago! you know how it is! anyway will check all this out when I get home,
    THanks again.
    Wait. Stop.
  10. #30
    May 2003
    SE Michigan
    OK. Run the benchmark. Record score.
    Install latest driver from nVidia.com.
    Benchmark again.
    Post results.
  1. What video cards will do widescreen??
    By Xanadu1979 in forum LCD/Display
    Last Post: 01-28-2004, 06:44 PM
  2. Does the EPIA5000 support regular drives & sound cards?
    By -al- in forum General Hardware Discussion
    Last Post: 08-26-2003, 08:46 AM
  3. Standard video cards w/ LCDs
    By new0deal in forum LCD/Display
    Last Post: 04-21-2001, 09:53 AM
  4. Video cards that display NTSC on boot?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-06-2001, 11:56 PM
  5. any opinions janton video cards?
    By Blackwind in forum General Hardware Discussion
    Last Post: 09-06-2000, 12:28 PM
