Results 1 to 5 of 5
Thread: Having problems with my Lilliput
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    I just got my Lilliput TM-710VGT from DigitalWW and I'm having trouble getting it to work with my CarPC. It works fine with my HomePC though, which is odd.
    I'm using an ABIT IS-10 motherboard for my CarPC and I started by using the onboard video (Intel Extreme Graphics 2). I thought maybe that was the reason it wasn't working, since it works on my homePC, so I took the video card out of my homepc and put it in the car PC (since I upgraded the home computer's card). I thought that would do it but it didn't.
    I also tried lowering the refresh rate to 60hz thinking that was it but it still doesn't work.
    Can someone please offer some advice?
    I also want to mention that I PMed Armen (from DigitalWW) asking for some advice on this and he hasn't writin me back. It says that he read my PMs (both of them) but he just didn't bother to write back, which I think is a little messed up. It's been over a week and a half too.
    -Rich
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    You sure your refresh rate settings on the car PC are low enough for your LCD?
    Dec 2003
    New Jersey
    Quote Originally Posted by jusatry
    How low should I have them at?
    Rich
    Mar 2004
    Quote Originally Posted by srcstc
    Rich
    does it work right now?
    i had such a problem when i switched from a normal monitor to the 17" tft at work, the resolution at refreshrade was wrong at the pc. when i corrected it it worked, but i dont know if you have the same problem..
    bye stef@n
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    If you have a monitor that works with your carPC, check the display settings. Set them to 800x600 or 640x480. Set the color to 4096 or 262k. Set the refresh rate to 60Hz. Then shutdown and swap monitors.
    What OS? Did you try to start in safe mode?
  1. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 07:58 PM
  2. Lilliput Touchscreen Problems
    By MWCARPC in forum LCD/Display
    Last Post: 04-21-2004, 05:33 PM
  3. lilliput touchscreen problems
    By dominic in forum Input Devices
    Last Post: 01-14-2004, 07:50 PM
  4. Replies: 15
    Last Post: 01-12-2004, 02:10 AM
  5. touchsreen problems on lilliput
    By mrzigzag in forum LCD/Display
    Last Post: 12-03-2003, 03:57 PM
