is your friend...
Is it difficult to remove the silver frame around the lcd screen ?
I am building it into my dash and need to be smaller.
Any howtos for that ?
What about the buttons and i/o's
Regards
is your friend...
bro, just use a small amount of force, pull the screws and then use a flathead or something and carefully pry the frame apart at the seam, and your done!!
New CarPC on the way again I think. I miss my old one!!!
Originally Posted by R3l0ad
which screws are we talking about?
i have of course searched, but there is NO tutorial about how to actually dissasembe the case....as far as i can tell....
I actually did a search to see if there was anyone that has shown or explained how to do this but I could not find any.
Thanks R3l0ad, but is it difficult to manage the input/output devices after the frame is off ? They are all connected trough the frame i think
perhaps u could use the tutorial on the digitalww website, they explain how to disassemble the lilliput 7in and fit the lcd panel into an in-dash housing...
I got my lilliput yesterday and within three hours had it in bits to see how my in dash install will go. Just remove the screws and it will come apart, unlatch the connectors and you can unscrew the screen housing. You can ditch the buttons and use the remote by removing the button pcb or extend the cable and relocate
http://www.tmz.com/wrx/lilliputLCD.html
Pin-out etc for Lilliput.
no write up eh?
Writeup Lilliput installation in TM-701L housing
Alex
90 300zx twinturbo conversion
Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
If you have the Lilliput in front of you it is easy.
1.Turn the Lilliput on it's front side.
2.Locate the 4 screws (one in each corner) and remove with small philips
3.With the flathead or exacto knife (flat head will work better) pry open the case.
4.Disconnect the connector with only two pins (once your inside you will see what i mean)
5.Disconnect the smaller ribbon cable (it was easier to disconnect the end that was plugged into the seperate board that the LED's and buttons are on)
6.Disconnect the larger ribbon cable
Disconnect the 4 pin connector
7.If you are taking the whole thing out completly (not just the front bezel) you must take a dremel tool with cutting bit to the back plastic housing to freen the vga cable. This is a delicate procedure becasue you dont want to damage the cable with the dremel
8.Disconnect the black/red wires to the speaker and pry from housing
Remeber where everything goes. and when you plug the small ribbon cable back in make sure you get it in there right or else the unit wont power on (i experienced that last night)
