Go into settings on MEdiaengine and toggle off the autodim feature at night...Originally Posted by G35Pimp
I was wondering if there is a way to se the screen's brightness and contrast permanently. I have a xenarc 700TSV. I set the brightness and contrast to 50/50 and it seems to stay that way everytime I start the computer which is good, but when I load up MediaEngine, it lowers the brightness for some reason. When I exit out of MediaEngine the settings go back to 50/50 like I want. Is there anyway to leave it 50/50 permanently?
-Noa
haha. thanks.Originally Posted by Litespeed
Okay so my computer has about a 60% chance that it will keeps my settings on my monitor when i start it up. How can I make that permanent? I have a mac mini and a Xenarc monitor. thanks
There is a software solution to that "my Xenarc can't keep the settings permanent" problem: PowerStrip. Install it, run it, go to the color profiles menu and increase the brightness, play with the other options too. The settings become permanent and it is pretty much the same as using the buttons on the Xenarc.
I think that question has been asked before, not sure if the same solution has been suggested before.
If you have a 700TSV, keep the defaults of the screen (brightness/contrast 33,33 I believe) and try increasing the brightness/contrast using powerstrip. Let me know what you see.
Giving it a try........
