Results 1 to 10 of 12
Thread: DOA Lilliput 8"
    Feb 2004
    Unhappy DOA Lilliput 8"
    I finally got around to turning on my new Lilliput from electronicar and it looked great for about 20 mins then the power went out and it doesnt work with the cigarette lighter adapter either. Please if anyone knows what I could do to fix it that would be great.
    Feb 2004
    check the fuses
    Feb 2004
    Unhappy
    I've been searching the posts and I can't find anything pertaining to this. If anybody knows anything I would really appreciate it.
    Feb 2004
    Question
    that's what I was thinking but I don't know where the fuses on the unit are.
    Mar 2004
    Sounds like mine, had a loose wire in the main white connector. Carefully wiggle & push the wires up into the white plug, see if the screen will flicker or turn on. One wire looked like it was never soldered & came loose. I didn't see any fuse in mine when I had it apart.
    Feb 2004
    Unhappy
    Mine just has a single barrel connector on it. there is no wires to push up into it. I have the 8" TS. It was fine one minute and then the next it just shut off and won't come on with either of the adapter that came with it. I wonder if Electronicar will exchange it for me (seeing I only had it for 2 weeks and actually only used it for literally 2-3mins)or are they going to be jerks and make me go through all the red tape crap with Lilliput.
    Mar 2004
    I have the 8" TS from electronicar also, the connector I had problems with is the main one at the bottom of the screen, looks a little like a DVI connector. Other than that it's worked great.
    Jul 2004
    That connector is a real problem, mine had a loose wire but its now traced and resoldered.
    Aug 1999
    Washington D.C.
    You should buy from a reputable dealer like Mp3car that tests all screens before shipment.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Don't mean to hijack, but that biodiesel, is that the homebrew stuff?
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
  1. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 07:58 PM
  2. Lilliput install in and Impreza, Lilliput issues
    By SubPuter in forum LCD/Display
    Last Post: 04-19-2004, 09:56 PM
  3. Lilliput 8" Touchscreen Display
    By Randomtask in forum LCD/Display
    Last Post: 02-06-2004, 02:12 PM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
