Results 1 to 5 of 5
Thread: Bizarre Lilliput
    Feb 2004
    Bizarre Lilliput
    Hi everybody
    I have a very strange problem with a Lilliput:
    I've disassembled the screen, enlarged the light cable (the 2 pole one) about 7 cm. and put appart the board, just enough to let me plug the original multiconductor cables.
    Well, it works fine, BUT: If the screen is off, the touch panel works. (I see it through the tv out) Just when I turn on the screen, the touch stop working!
    I've checking ground loops, pins, short circuits... nothing.
    Since USB touchscreen board is feeded by the USB 5v. and ground pins, it works even if the rest of the screen electronic is off. Due to this I can't understand why when it lites, it stops working. Maybe a hi-voltage interference?
    Has anybody had the same problem? Has anybody any idea about how can I get rid of this? Tonight I have a presentation of my prototipe...
    Help!
    Thanks a lot,
    Miguel.
    Feb 2004
    anybody?
    Quote Originally Posted by mpelaz
    Hi everybody
    Help!
    Thanks a lot,
    Miguel.
    zvi
    zvi is offline
    Constant Bitrate zvi's Avatar
    Jan 2004
    Tbilisi, Georgia
    what if you put everithing back as it was before, and see what will happen
    '93 Opel Vectra A with Custom Dash with 7" lilliput
    VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
    http://zvi.home.ge/pics/?dir=vextra
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Is there a power drain when you switch on your tft, lowering the voltage to the usb ports.. thus not having enough power then to power the screen ?
    Apr 2003
    Another possibility - RF interference from the lengthened inverter cable to the backlight. This carries high voltage AC, typically 180VAC at 30 to 100 kHz. Keep this cable away from other cables carrying low-level signals, especially the 4-wire touchscreen cable. Try this and see if this helps.
  1. No Signal on Lilliput 7 Inch touchscreen.
    By SuperDave01 in forum LCD/Display
    Last Post: 05-04-2008, 10:36 AM
  2. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 07:58 PM
  3. Lilliput install in and Impreza, Lilliput issues
    By SubPuter in forum LCD/Display
    Last Post: 04-19-2004, 09:56 PM
  4. In-Dash 7" MOTOR TFT or Lilliput 7" Touch Screen
    By JonX69 in forum LCD/Display
    Last Post: 03-06-2004, 02:22 PM
  5. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
