Results 1 to 3 of 3
Thread: Lilliput Resolution Problem W/ Routis 2004
    Dec 2003
    Okay I love my lilliput, I run it at 800x600 in windows Xp connected to a Epia-M 1000 onboard video card, but I am running routis 2004 (GPS software) and the buttons are way small with this resolution. This lcd is way weird with resolutions, when my carputer boots it says "overrange" until the windows welcome screen comes up, why is this happening. When I check display properties in control panel, the lowest resolution is 800x600 and it goes way up from there. Should I be running this screen at 800x600 & how can I lower this so Routis 2004 looks better....thanks in advance.
    Nov 2003
    Talking
    Quote Originally Posted by drmaximus
    My lilliput stays overrange after windows boots and I have to cycle the power on the lilliput to work. Think its a problem with all lilliputs, nobody has an answer yet. I also run Routis. Are u running xp? U can set it to use large fonts... this will make everything bigger, not just the fonts in Routis!! I ran that for a while but it made other apps hard to work with. Not sure how to lower the res of the lilliput lower than 800 x 600
    Variable Bitrate Leddy's Avatar
    Mar 2004
    Control Panel->Display->Advanced->Adapter->List All Modes
    Select which restolution, color depth, and refresh you want to use. Click ok all the way out.
    2001 Pontiac Grand Prix GTP Sedan (Sold)
    2007 Scion tC
    WhereIsMyGPS.net Online Tracker
    http://www.cardomain.com/id/leddy
  1. FS: Touchpad mouse, Microsoft Streets & Trips, Routis 2004
    By srcstc in forum Classified Archive
    Last Post: 05-04-2004, 05:19 PM
  2. Routis 2004 software
    By greddy0 in forum GPS
    Last Post: 03-02-2004, 07:16 PM
  3. Small Lilliput display problem
    By Da_Teach in forum LCD/Display
    Last Post: 03-01-2004, 07:23 PM
  4. Deluo routis 2004 Screen Shots
    By angeLCD in forum GPS
    Last Post: 01-13-2004, 09:44 PM
  5. Lilliput LCD, 2000 Celica GT and voltage problem
    By Goose in forum LCD/Display
    Last Post: 12-29-2003, 05:53 PM
