Results 1 to 5 of 5
Thread: Was working great...now its broke (Datalux 10.4)
    Feb 2003
    SE, PA
    Im at my wits end, I hope somebody can help me. I spent 2 days getting the touchscreen to work on my new LMV10R. Got it working perfectly so i took the lcd and controller out of the case to figure out how Im gonna install it.....ended up putting it all back together and now it doesnt work..
    When it first turns on I get black/white lines, then it all just fades to white within a few seconds. The Brightness control buttons work. I tried reseating the controller card, no change. Checked all the connections on the 3.3v mod, they are all good. I cant believe this, please somebody tell me its not broke
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
    Banned outragis's Avatar
    Jul 2002
    Vermont
    Datalux help needed!!
    Someone ...help this guy out! He's a great guy, with a huge website with lots of members, and has nothing but great things to say about this site there...so all you datalux guys check in!!
    Quote Originally Posted by blazinlow
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    The only thing that I think you can do is double check all the connections again especially the internal ribbon cables that connect directly to the display. This is the kind of problem that a loose internal display cable will cause. They are easily teared if you are not careful so check for that too. If your brightness controls bring up an OSD you can be pretty sure that the problem comes before the lcd itself.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Feb 2003
    SE, PA
    thanks god of cpu, your suggestion made me open it up again and take a real close look at it.. Theres a plug on within the lcd panel itself. It looked fine, but when i pushed on it, it snapped down a bit...
    Works fine!!!!! Im so glad heh I couldnt sleep last night I was so mad.
    Thanks again
    Jul 2002
    Vermont
    Glad you figured it out...the new widescreen I got did the same thing, it was a conection on the switch! I couldn,t sleep either! It bugged me all nite, Next day I started over, and bam..It worked!!
  1. Great working tank circuit with backup bat.
    By NightHunter in forum Power Supplies
    Last Post: 04-29-2004, 09:51 PM
  2. FS: Datalux 10.4 touchscreen
    By Jeff in forum Classified Archive
    Last Post: 03-07-2004, 10:18 PM
  3. EPIA M and Datalux not working
    By Typhoon747 in forum LCD/Display
    Last Post: 12-10-2002, 07:39 PM
  4. Datalux LMV10R 10.4 Inch Touch Monitor
    By KaBoom in forum Classified Archive
    Last Post: 10-15-2002, 07:28 AM
  5. FS: 10.4 Datalux LCD/ 10.4 Touchscreen
    By Typhoon747 in forum Classified Archive
    Last Post: 05-12-2002, 06:53 AM
