Results 1 to 4 of 4
Thread: I broke my Intec PSone screen...help!
    Nov 2003
    Olympia, WA
    I pulled apart my Intec screen and the next time I went to look at it, it was broken! I now have four wires and I don't know where they go. Two look like ground wires and two are possibly power wires. I took pics of all the little circuit boards and the wires. Can anyone tell me to which circuit board and where they go? I have a friend that can solder them back on if need be...Thanks in advance!
    In picture one I circled the wires that came loose. The next 5 pics are of the various circuit boards.
    Nov 2003
    Olympia, WA
    Last picture
    This is the final picture...Thanks again for your help...
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    The red and white ones go on the long backlight inverter board. There are two pads on the wide end - the one nearest the blue component is the red wire, and the one nearest the long edge of the board is the white wire. The long black wire goes to the big pad in pic 3 near your thumb on the 1 X 2 shaped board. I cut the short black wire off and its just floating now. Not sure where it was but apparently it isn't needed. It may have been on the foil shield?
    Fabricator
    Nov 2003
    Olympia, WA
    Thanks for the help...I'll get my buddy to solder it and let you know how it goes!
  1. psone screen
    By belmontboy in forum LCD/Display
    Last Post: 03-13-2004, 02:01 PM
  2. psone screen video problem
    By WILD9 in forum ME Archive
    Last Post: 11-27-2003, 01:38 AM
  3. psone screen to computer psu adapter?
    By doomkiller99 in forum Power Supplies
    Last Post: 11-01-2003, 01:22 AM
  4. Composit to PSOne screen without Composit socket
    By Daninino in forum LCD/Display
    Last Post: 09-29-2003, 11:32 PM
  5. psone screen, HELP!!
    By kardas in forum LCD/Display
    Last Post: 10-10-2001, 05:31 AM
