Results 1 to 3 of 3
Thread: Lilliput USB cable
    Jun 2003
    Memphis - TN
    Lilliput USB cable
    This USB cable that came w/ the lilliput 7.2" Touchscreen. HOw does it work?
    I have an RCA camera I want to use w/ my EPIA M9000. Anyone know how to get this working? Any help would be appreciated.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    it isnt a usb cable, it just uses a usb connector, lilliput should of used something else really to avoid confusion. if you plug a usb connector into while the screen is powered up, you will shove 12 volts down the line into your usb device.. not good.. so dont try it.
    CdR
    Mar 2003
    Basingstoke, Hants
    Quote Originally Posted by Custommx3
    There are two cables with USB connectors on them. The one on the cable with the VGA adapter plugs into the USB port for the touchscreen. The other cable has a USB plug on one end and the other end ahs 3 plugs (Red, Yellow, White) and a black 12v socket. Plug your A/V and audio into these. All this does is connect the A/V sources to the monitor, it does not connect it to the PC at all.
    Doug
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. Lilliput - linux supports usb touch screen?
    By chenko in forum LCD/Display
    Last Post: 10-03-2004, 06:58 PM
  3. FS: 25cm 40pin Lilliput Screen Cable
    By JFS1179 in forum Classified Archive
    Last Post: 02-22-2004, 11:27 PM
  4. USB gps mouse , max lenght cable
    By BOND007BE in forum General Hardware Discussion
    Last Post: 12-17-2003, 07:54 PM
  5. Lilliput cable...
    By Custommx3 in forum LCD/Display
    Last Post: 12-10-2003, 10:23 AM
