Results 1 to 10 of 12
Thread: TM-701L housing, how is it secured ?
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    ok, I have now converted my lilliput, but cant figure out how to secure the housing into the din socket.. it didnt come with any fasterns or anything.. should it of done ?
    any ideas will be very helpfull
    thanks
    Steve
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    heh join the club...i was lucky enough that when the housing is in my dash, it is such a tight fit that it won't budge at all
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
    Feb 2004
    Manchester
    I suppose I could 3m double stick it to the radio case below.. this would prob work..
    still its not the best answer..
    I'm still on the look out for a cheap motorised case I can butcher..
    Mar 2004
    Cape Cod, MA
    How hard do you think it would be to add a motor to that housing?
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    Quote Originally Posted by briang
    im actually working on that now
    g35
    g35 is offline
    Mar 2004
    Board Size
    CdR,
    Would you be able to tell me what the EXACT dimensions are for the Lilliput board. I want to purchase a Lilliput and take it out of the default housing and place it in one that is built for my car. Thanks
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    If it's any help.
    My car has a single DIN opening in the dash. I bought the TM case and mounted my Xenarc monitor into it. I then bought a DIN mounting box off of eBay for about five bucks delivered and cut off one side of the box. This makes it large enough to mount the TM case inside of it. I then installed the monitor/din box into the hole in the dash and it fits great without any mounting kit or anything else. I hope that helps, it took me a couple of days to figure this out but it works great.
    Peter
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    Feb 2004
    Manchester
    yeah sure, will do it in the morning, its a bit dark outside at the mo.. I have also been searching for different housings.. found a couple on ebay, just seems alot of money to waste if it cant be done..
    just as a non motorised housing this one looks ok.. OWW just noticed its half auto motorized.. OK going to order one.. F**. it
    theres 6 buttons on it, only 5 are needed, so I will be sticking the 6th button on ebay.. or if anyone wants to buy it.. let me know
    Feb 2004
    Manchester
    as for mounting this housing, I have a couple of old car stereos in the loft, I will go and see if one can be adapted.. I cant believe the tm701 doesnt come with any casing. Also the little screws that hold the front cover plate, the one you need to remove to take the draw out.. well these screws were 4, now 3.. infact theres only 1 left in, I aint a clue where the others have gone.. crap idea I think anyone lost these screws or is it just me ?
    Mar 2004
    Cape Cod, MA
    Quote Originally Posted by BoraXP
    How far along are you? Do you feel it is easier than building one from scratch?
  1. Replies: 13
    Last Post: 12-24-2005, 05:14 PM
  2. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 06:58 PM
  3. Calling all TM 701L users with GPS
    By fyleow in forum LCD/Display
    Last Post: 01-26-2004, 01:28 AM
  4. TM 701L Owners
    By chut in forum LCD/Display
    Last Post: 10-08-2003, 02:08 PM
  5. Replies: 2
    Last Post: 07-16-2002, 08:15 PM
