The cable connector socket you'd need is a Hirose DF19-14S-1C, shown here:Originally Posted by sr_ryan1
http://rocky.digikey.com/WebLib/Hiro...9%20Series.pdf
In theory you could make your own wiring, but the connectors are hard to find (digikey doesn't have them in stock - you can order 1000 at a time, if you want), and crimping the tiny connectors requires an expensive tool.
Digikey does offer pre-made jumper wires with other Hirose connectors, but only up to 12" long.
With the connector shells and some pre-crimped wires, you could make your own cable.. neither of which is currently available, apparently.
LinkBack URL
About LinkBacks
