Page 20 of 28 FirstFirst ... 10111213141516171819202122232425262728 LastLast
Results 191 to 200 of 274
Thread: My solution to Auto Power ON Lilliput screen
  1. #191
    Variable Bitrate looneeii's Avatar
    Feb 2005
    Gatineau, QC, Canada
    Kinda off-topic, but as an alternative how would you solder an external on/off switch to liliput instead of leaving it auto-on because I don't need to drain my battery the way I have it setup in my GP. Thanks.
    99 Grand Prix Grand Tigress
    HW
    Liliput 8in TS
    845GVD MITX w/ 2.4 Mobile P4M (478 MB)
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
  2. #192
    Nov 2004
    Netherlands
    Quote Originally Posted by looneeii
    Use a relay to switch the batteryline on/off from the ignition key...
  3. #193
    Feb 2005
    Quote Originally Posted by DJSmiley
    HUH?
    HW
    Liliput 8in TS
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
  4. #194
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    FYI - Mod made simpler.
    By leaving the resistor in, I've added just one 150uF capacitor and it works fine.
    Getting a 150uF cap is tough, especially one that is not huge. I found a 6.3V one in DigiKey that is pretty good.
  5. #195
    Cool!
    But has anyone tried this with an 8" lilliput yet? Last time I tried to mod something based on a 'similar' model, I ended up buying a replacement hud.
  6. #196
    Low Bitrate lazarus's Avatar
    Aug 2003
    Leeds uk
    despite haveing done no mods to my 7" lilliput it turns on by its self any way. its the newer revision of the board and its hooked up to an opus 90watt psu (positive and ground), i also remove it completely from the car on a night so it has kind of back up power but still it fires up by its self in the morning. when i get the a chance i'll go and check if there are any model/revision numbers on the back to compare against.
  7. #197
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by phc
    Quote Originally Posted by joshthepilot
    Since 100K and 10uF work, 100uF cap would also work in this setup.
    I pointed this out on page 2 of this thread (post 29) but no one try it.
    Post 30 is Coyote reply
    [edit]correct link to Coyote post 30 [/edit]
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  8. #198
    Sep 2003
    Beach City, Socal
    Yes you did. And now that I see it, I wish you would have rebutted against that this could be damaging.
    The cap, regardless of size really has the same effect as the button. There is no way the charge would damage the mcu, the circuit, or the power button.
    You have done it this way Matrix? And if so, tell us how well it works.
    Nope I didn't mode my LCD for this auto on yet that is why I don't know how it works and how reliable it is.
  9. #199
    Feb 2005
    Anyone do this on the 8in liliput yet?
    HW
    Liliput 8in TS
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
  10. #200
    Apr 2005
    works on lilliput 8" TS too.
    the circuit is slightly different, with the switchboard connector on back rather than front, so I routed the - wire of cap through a hole to back to get a ground point, but front side is same.
  1. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
  2. Complete solution, COMPUTER, SCREEN +DVD player for your car!
    By wrxmaster in forum Classified Archive
    Last Post: 07-09-2004, 03:26 PM
  3. Power button for Digitalww 7" touch screen
    By imi1232000 in forum LCD/Display
    Last Post: 02-15-2004, 12:02 AM
  4. Lilliput and adding another screen..
    By Custommx3 in forum LCD/Display
    Last Post: 01-28-2004, 06:05 PM
  5. Power Acoustik 5.6" Lcd screen HELP!!!
    By trilogy98 in forum General Hardware Discussion
    Last Post: 09-05-2000, 11:29 AM
