I have a 10.4 touchscreen from Dynamix Computers. My problem is that the same button that turns it on, also switches between the 3
video inputs. I pulled a lead from the UC side of the existing
power button, and hooked it to one side of a momentary switch, with the other side to ground. I just push this button to turn the screen on. No, in my install, the 'factory' button was not accessible.
So, I was thinking...could I build a circuit like this one, and make it external, on the wire I brought out? Where this circuit has 5v, mine would have 12 (vehicle power). Also, with my monitor, if you hold the button too long, it will switch to the other inputs, and eventually off. Just about 1 second seems to be about right. Varying the capacitor and resistor values would fix that.
Problem is, I've just exceeded my electronics knowledge. Anyone want to start me in the right direction with component values? Please??
Toby J.
