Page 9 of 28 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 274
Thread: My solution to Auto Power ON Lilliput screen
  1. #81
    Oct 2003
    Vancouver, BC
    Is it just the older screens that need this mod done? I just got my Lilliput yesterday and the screen turns on automatically when I plug the power in. I was all ready to take the screen apart to do this mod too
  2. #82
    Feb 2004
    Quote Originally Posted by LittleDragon
    where did u get it from?
    thanks...
  3. #83
    Oct 2003
    Vancouver, BC
    Quote Originally Posted by icet
    thanks...
    I bought mine from Shillier, screen works great. So far, I haven't run into any problems that people are complaining about.
  4. #84
    Feb 2004
    do u have a web link?
    are u sure about auto turn on with newer model?
    if it does, that would be great..
    thank you
    icet...
  5. #85
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    not so great if your converting it into a indash housing.. this would be the last thing u need.. the heat generated could burn sumot out when its shut inside.. lets hope not
    CdR
  6. #86
    Raw Wave
    Jun 2003
    You can always only allow it to turn on when the screen is out...by a microswitch perhaps
  7. #87
    Constant Bitrate ZenerDiode's Avatar
    Nov 2003
    Bay Area
    ack, my lilliput doesn't have that same bracket to ground to...the connector is ever so slightly diffrent. that bracket that coyote grounds to is actually inboard/on the connector itself on mine....think i could still ground it there?
  8. #88
    Aug 2003
    Michigan
    very slick. now if i only had a lilliput
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
  9. #89
    Melbourne, Australia
    Talking
    Well, it works as advertised... Now I'm nice and happy Only have to get a shutdown controller happening soon
    edit: oh yeah - and it only cost me $0.65AU
  10. #90
    Jun 2002
    Malaysia
    Problem here, it could be slightly off topic but then again it could be on topic.
    I've been trying to replace the round cable to a ribbon cable (trend these days =P) and suddenly my lilliput went crazy. Call me crazy, but does the 10 pin round cable thing have any effect on the powering up and down of the lilliput? I'm thinking, even if I mess up on the wiring here, it shouldnt affect the on switch right?
    I didnt do this coyote's mod (yet).
    I have the lilliput to turn on automatically by shorting the two ribbons much like what shakes did - except I did it on the ribbon.
    Well after finishing my conversion.. and after applying power.. my lilliput turns on then off then on then off every second. The second its on I can catch a glimpse of "No Signal" and the desktop and it keeps going like this until I cut off the power. What's funny is, it does this even if I TAKE OFF the power-on-mod above. It has no effect!
    Maybe I accidentally soldered somewhere but I cant find it maybe I'm not looking hard enough.
    I took some measurements.. you know the circuit on page 1? Where coyote removed the resistor? Well I took an ohmic reading from the ground (as in pic) to the terminal (of the resistor that was removed - from the pic it would have been the other leg of the resistor which now sits alone) and its 0 ohms.. meaning that terminal is also ground.
    Is that right?
    That means, on coyote's schematic diagram.. that resistor on my lilliput is connecting the +5 to ground.. meaning the switch is always on. But how could it be always on when I'm not even pressing the power button?
    Even if the switch is always on for some reason.. it shouldnt be going off and on and off and on right? Sometimes if I wiggle or just leave it alone it would display the desktop or the "no signal" for minutes or so.. which leads me to suspect the work on the ribbon cable.. but that leads me back to the first paragraph.
    could anyone with a good electronics knowledge help me detect what is the problem? Maybe you could get the voltages on the terminals and compare with mine? I dunno.. its late midnight here now and I think I could use some sleep.
  1. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 07:08 AM
  2. Complete solution, COMPUTER, SCREEN +DVD player for your car!
    By wrxmaster in forum Classified Archive
    Last Post: 07-09-2004, 02:26 PM
  3. Power button for Digitalww 7" touch screen
    By imi1232000 in forum LCD/Display
    Last Post: 02-14-2004, 11:02 PM
  4. Lilliput and adding another screen..
    By Custommx3 in forum LCD/Display
    Last Post: 01-28-2004, 05:05 PM
  5. Power Acoustik 5.6" Lcd screen HELP!!!
    By trilogy98 in forum General Hardware Discussion
    Last Post: 09-05-2000, 10:29 AM
