Results 1 to 8 of 8
Thread: Kiosk Touch Screen
    Kiosk Touch Screen
    Does anyone know what would be involved in using a different motherboard or video card on the screen of this unit?
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2795678976
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Quote Originally Posted by MSUC5Vette
    You need to read this thread Found someting interesting on E-Bay!!! all 657 messages in it!
    In short you could add a PCI graphics card, I guess, but not to use with the built in screen. You could also put a different MB in but not hook it up to the screen as the controller is built in to the supplied MB.
    The good news... you can upgrade to a 1.4GHz Celeron... happy reading!
    Chris.
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    instead of a 12 inch 800*600 at 225$ + shipping, why not a 10.5 inch 1024*768 at 150$ + shipping??
    FS: 400MHz PC w/ 10.5" touchscreen with Win98 LOADED Special only for Mp3car members!
    -Mars
    Maximum Bitrate none's Avatar
    Sep 2003
    Quote Originally Posted by Marsupial
    I've considered both and the ebay one is much better.
    Feb 2004
    Montreal
    "much better" is a big word.
    yes, it has more ports, better RAM/CPU/HDD and fits PCI components, but it has a lower resolution which you get stuck with and is way bigger. I really mean it is huge compared to the one from civicduties.
    paying less for a smaller form factor... sounds like a great deal to me.
    -Mars
    Sep 2003
    Faster out of the box, higher upgrade ceiling (if the other is upgradable at all ,) no external PSU required, FAR better customer service from the seller, MUCH more documentation available. I can come up with more if you want.
    Do you have anything other than resolution? (A dubious advantage as it makes accurate touchscreen use far more difficult.) The size is not a concern for me, as it is used as a home theater component.
    " Display is more than 1024X768 " is a strange expression. I would suspect it is compressed. If it is real XGA, it will be better for a carputer, although 12" one may be more attractive for in house use for its better upgradability. could you comfirm it is TFT XGA?
    Feb 2004
    Montreal
    XGA is the display standard for 1024*768 and the unit from that thread is doing it good.
    If you go higher resolution, you're into a "virtual screen" and it is kinda ennoying.
    this said, the screen is crisp at that resolution.
    Other owners of those units are looking at upgrading it, the CPU is not soldered, nor memory or HDD. You have PCMCIA and USB1.1 onboard - you can then make whatever you want.
    the other one, bigger screen but lower res. You're stuck with that res even if you upgrade everything else.
    -Mars
  1. Where to find a touch screen overlay?
    By bayere in forum LCD/Display
    Last Post: 01-13-2004, 12:32 AM
  2. touch screen for customized size lcd screen?
    By iPal in forum LCD/Display
    Last Post: 09-25-2003, 03:31 AM
  3. UPDATE ON: TM-701L and Touch Screen Kit
    By digitalww in forum LCD/Display
    Last Post: 07-12-2003, 12:39 AM
  4. FS : 12 Inch Touch Screen / 25 Foot Cable
    By ezfilez in forum Classified Archive
    Last Post: 04-16-2003, 03:08 PM
  5. I have no touch screen... how do u make an interface?
    By domdino in forum General Hardware Discussion
    Last Post: 10-07-2002, 09:39 AM
