Results 1 to 10 of 14
Thread: Extend lilliput ribbon connector?
    Feb 2004
    Does anyplace on the internet or anywhere sell a ribbon cable that is the same pin number and connection style of the lilliput 7" control panel? Basically I am looking to mount the control panel somewhere else with custom buttons, but i need a longer ribbon cable. anyone know?
    Mar 2004
    a vga extension and usb extension wont work for you?
    Feb 2004
    no no no. The screen is cusom mounted in my dash. However i didnt like the buttons showing, so the front panel is just sort of dangling/taped to something behind the screen. I would like to be able to use the buttons however the ribbon connector that goes from the button control panel to the lilliput mainboard is very short, i want a longer one of those if possible.
    Zac
    Zac is offline
    Feb 2004
    VA
    Extending the leads on the IR sensor is much easier if you would rather use a remote then all the buttons....otherwise good luck, its a 13-pin cable by Sumitomo. Mine is torn across 3 wires (unused wires luckly) and I also need to find a replacement soon.
    I've done plenty of searching, but its 3am here and a little late to e-mail/call companies about getting a custom cable.
    If you find a good source do share though :-P
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    I doubt you will be easily able to find such a cable. They just aren't really manufactured to be that long.. Check with Digi-Key or Mouser .. they are the two best places that you could get a single cable if it exists.
    If it doesn't exist (and it probably doesn't) your best bet might be to wire external buttons of your own to the button contacts on the lilliput board. The buttons all use a common ground, so it wouldn't be any more wires than is in the ribbon cable. You could get some of that multi-conductor wire to keep it all neat and tidy.
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    Am I missing something? bbasically you just want wires? check the lilliput ~~> indash pocket DIY and just extend your wires.
    Mine needs to be updated.
    May 2003
    hi
    i have a longer ribbon on my display, i mailed a couple of companies that sells/makes this cabels and got a sampel from them .
    The funny part is that its not the 13-pin in both ends, one of them is 14-pin (thats what they call quality !!!!)
    i have one spare cabel but its 28-pin with 0,5 mm pitch, i misunderstod them when i talk to them. But it fits, its just that on pin takes to wires.
    //Peter
    Constant Bitrate Aftaab001's Avatar
    Mar 2004
    Kent, UK
    I couldn't be bothered to look for an IDE flat extension cable so i cut the ribbon cable halfway and used normal printer cable to extend the control to a metre roughly. check my link underneath.
    My project is also there
    http://uk.f2.pg.photos.yahoo.com/ph/...&.dnm=6143.jpg
    Aug 2003
    Amarillo, TX
    Wow did you completely coat the entire backside of your screen with hot glue?
    MY CAR IS FOR SALE!
    Feb 2004
    Using remote would be great. Is there a writeup somewhere on how to move the IR sensor or should i just search? Can you power on the screen via the remote? thereby making it not necessary to modify the sceen to power up automaticaly (like Mastero did)
  1. WTB: BROKEN Lilliput 619!
    By masch in forum Classified Archive
    Last Post: 12-14-2004, 04:58 AM
  2. Replies: 37
    Last Post: 08-06-2004, 04:23 PM
  3. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
  4. Replies: 0
    Last Post: 02-17-2004, 07:10 PM
  5. name of ribbon connector?
    By etrik in forum General Hardware Discussion
    Last Post: 08-12-2001, 12:49 AM
