Did anyone try their character LCD displays under the recomended operating temperature? Did it break in two, didn't work at/much or whatever...
There must be people here that life where there's cold winter....
I was thinking getting a LCD screen like the Hitachi HD44780. The operating temparature range of the one I was looking at was -10 C to 50 C (I dont know how much would that be in Ferenheight). What would happen if I tried to run it under -10 C , before the car is heated up in the winter. Would it just not display properly or would that break something. Also, the non-operating minimum temperature is of -20 C. I beleive the temperature here goes down to -30 C sometimes. Would that be a problem?
JP
Impatient, aren't you?
I used a Crystalfontz HD44780 compatible standard LCD through all of last winter. The display's update slows down a bit when really cold, but it still works well outside the published temperature range.
Thanks for the info
when cold the screen will literally freeze and will fade out till it warms up. pretty cool actually![]()
conflicting views on long term damage from that.
I figured that the best thing to do yould be to buy the 4x20 blue LCD screen with a white led. It can operate at -20 and looks just too cool... At 30 US, I guess its not bad.
