Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: Question about Dual Monitors in XP
    I am adding a motorized Kenwood to my Xenarc system.
    I would like to use both montiors.
    Is there a program or something that will automatically move the top window in the main screen to the secondary screen, and then back to the main by just hitting an icon or button etc?
    Sep 2003
    Northeast Ohio
    Even though XP says it will support dual monitors, I believe the Only way to do what you want is to have a video card that will support a dual monitor set-up.
    System:
    Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
    Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
    Feb 2004
    your video card has to have 2 outputs, if you have a card that has a vga out and also a tv rca out you can do it. vga to the xenarc, and rca to the kenwood, you can then select which monitor is on the top, right, left, or bottom.
    Dec 2003
    Long Island
    Quote Originally Posted by MSUC5Vette
    First of all, what graphics card do you have? Before you think about the software side of it, how will both monitors be connected to the PC?? Are you splitting a single VGA output into 2?? If so, then no software program would be able to distinguish one output from another.
    Like infinkc said, if you have two completely separate wires connected to different outputs on your graphics card (new nVidia cards have S-vid, DVI, and VGA outs), then
    there should be a program that may help you out. I know that nVidia drivers include basic dual-display software that allows you to output a full screen video to one monitor, while having full use of the desktop on the other. As far as a program that displays the active window in its own screen, I'm sure one exists...... search it at a software site (CNet downloads....etc).
    Low Bitrate Dr Jeckyl's Avatar
    Mar 2004
    Bakersfield, CA
    Whoah
    first of all, XP supports dual, quad, up to 9 monitors.
    to power these monitors, you can have ANY video card that is PCI or better (PCI or AGP, or one of those with dual output, etc.)
    Be careful about dual output cards. Several of them simply output two copies of the same signal, most using two different interfaces so that you can choose which monitor you use (whether vga, dvi, or rca).
    To activate multiple monitor support, right click on the desktop, select settings, and then click the advanced properties tab to configure how you want the monitors configured.
    Now then, let's get to the point of switching how your monitors display ther images. I think (this part I'm not TOO sure about) that you could simply add another user account and set up those monitors differently. Switching user accounts would then toggle the images on the screens.
    Hope this helps,
    Marc
    Newark
    Quote Originally Posted by Dr Jeckyl
    Hope this helps,
    Marc
    I have been running dual monitors for two years now on my home computer, although I don't know if such as program exists for what you are looking to do, but I know what MSUC5Vette suggest will not work at all.
    Now, what people are saying about having the proper hardware to do it is correct.
    If I come across software or develope software to do that I let you know.
    Quote Originally Posted by nadthomas
    What do you mean what I suggest won't work at all? I didn't realize I suggested anything.
    I understand how to activate multiple monitors, I have done it on my desktop as well.
    I have an ATI card on my laptop which does support dual monitors. I can extend my desktop to a second monitor.
    I guess I am not being clear on what I want to do.
    For example:
    I have Winamp running in my primary display.
    I want to move it to the secondary display so I can still see it while I operate my GPS program on the primary screen.
    Instead of dragging Winamp to the second screen which is going to be a PITA with a touch screen, I would like to hit an icon, hot key, etc to have Winamp be automatically drug to the other monitor.
    Then if I want to change songs or something I again would like to be able to hit a hot key so I can operate winamp in the primary display and then move it back to the secondary.
    Any ideas? Does this make sense?
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    Don't know about ATI, but nView (with nVidia cards) does that.
    Blackpool, UK
    hi
    you can get hardware vga splitters, dont know if this will do exactly what you want put you have 1 vga in to the device from your video card and you get two+ vga outputs. these devices arent cheap though, but will give you multiple monitor support from whatever video source you provide it.
    regards
    matt
  1. "Welcome" screen on XP question
    By carpcnoobie in forum Newbie
    Last Post: 03-24-2004, 04:20 PM
  2. A nOOB question about monitors.
    By GATrooper in forum LCD/Display
    Last Post: 10-12-2003, 02:21 AM
  3. Probably a dumb question, but do I have to actually buy XP?
    By -al- in forum Software & Software Development
    Last Post: 09-28-2003, 03:53 AM
  4. Windows XP Hibernating Power Question
    By Rom in forum General Hardware Discussion
    Last Post: 08-01-2003, 11:59 AM
  5. XP/ Linux mandrake dual boot
    By MAJALO1 in forum Off Topic
    Last Post: 03-05-2002, 02:52 PM
