Results 1 to 3 of 3
Thread: Lilliput wireing??
    Jan 2003
    AL
    Lilliput wireing??
    Hi, i want to cut the lighter plug off and wire the lcd directly. There ia a solid black wire and one with a stripe. Which wire is the positive and negative?
    Thanks,
    Bobby
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    look for somewhere with - --( o ----- + then center of the plug usually denotes positive along with teh marked wire (white in yourcase)
    And the outside is usually negative with the unmarked wire.
    But use a multimeter to check.
    Mine needs to be updated.
    Constant Bitrate ncamara's Avatar
    Dec 2003
    Hampton, VA
    I wouldn't suggest cutting on the plug end unless you have some sort of regulated supply you're hooking up to(such as an Opus). If you're going to plug straight into vehicle power, dissassemble the cigarette lighter plug thing and use the electronics in it.
  1. WTB: BROKEN Lilliput 619!
    By masch in forum Classified Archive
    Last Post: 12-14-2004, 03:58 AM
  2. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 06:58 PM
  3. Replies: 1
    Last Post: 04-11-2004, 08:12 AM
  4. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
  5. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
