Has anybody ever got lil/Xen screen to clock onto native res?
Hi
I have had every screen going and tried lots of timing paramters with all the screens and I have never managed to trick the vga controller into displaying 800x480 natively.
The only screen I have ever managed it on is the first generation xenarc and it looked amazing, like a tft screen should.
I have tried on a second generation "res sensing" xenarc and it even if it accepts 800x480 with tweaking and fills the screen it still doesnt match the pixels correctly.
I have tried the liliput and it gives the same blurred image.
The only current screen I can get a good image on is the 8 inch lilliput which is 640x480 proper clocked image.
So, has anybody ever managed to trick the vga controller on a widescreen screen to clock native resolution? If you have can you post timing parameters.
The ones I use are:
HORZ:
Active 800
FP 72
SW 56
RP 72
TOTAL 1000
VERT:
Active 480
FP 20
SW 5
RP 20
TOTAL 525
The above fools the screen into thinking its 640x480 and this seems to work on all controllers I have tried, but doesnt give a clean image.
