Results 1 to 6 of 6
Thread: Lilliput Power
    Constant Bitrate blustreak's Avatar
    Jan 2004
    ATL GA
    Lilliput Power
    I just got my 7" lilliput today and a friend and I were hooking it up. We didn't want to take the unfinished computer outside so we brought in a car battery and cut off the cig lighter adapter. We hooked up the two wires and the little egg on the wire basically blew up and now we have no power.
    I know "that was stupid" blah blah blah but I need help. Can I get a generic one? Do I need that particular cord? What should I do?
    I need help,
    thank you
    Constant Bitrate JayKaye's Avatar
    Jan 2004
    Sydney, Australia
    Open up that egg thingy (regulator) and see if you just blew a fuse.
    If not then you will need to get a replacement for the egg OR you could run the screen directly off the 12v line in your carpc. You dont need to use the same wire but make sure you replace it with another wire the same gauge (thickness) or thicker.
    EDIT: get a few opinions before hooking the screen up to the 12v line without a fuse. I dont want to be responsible for a broken screen
    Aug 2003
    Moncks Corner, South Carolina
    No Wait! I Blew my egg up too
    What you did was hook it up backwards
    What you need to do is go to wallmart and buy a cigarette lighter adapter that outputs 12 volts, This way your power is regulated.
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    yep, any 12V regulated source that can put out 1 amp will take care of your screen - just use the same barrel plug and PLEASE use a fuse....and maybe a multimeter?
    Jan 2004
    ATL GA
    Quote Originally Posted by StangBoyCIC
    Ya after reading the forums, I realized my friend hooked it up backwards.
    So all I need to do is get a generic one from wal-mart?
    Sounds good, thanks everybody
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    well no get a car adapter plug that iwll put out 12v at 1A (or so) and then just splice the plug going to the lilliput to this new car adapter..
    Mine needs to be updated.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. Simple Idea for keeping power to inverter while cranking....
    By syclone477 in forum Power Supplies
    Last Post: 03-23-2004, 09:03 AM
  3. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 06:32 PM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 10:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 09:33 AM
