Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 91 to 100 of 119
Thread: FAQ: Everything you need to know about your Lilliput
  1. #91
    Low Bitrate lor109's Avatar
    Mar 2004
    2008 Eby701
    Review, detailed dissasembly pictures,sSunlight picture for 2008 EBY701
    Lilliput screen fro ebay what do u think?
  2. #92
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Lilliput 10.4 Wiring -- How the Touchscreen Wires Connect
    If you've uncased your Lilliput 10.4", Model 1042, I could use some help. In disassembling mine, I accidentally (violently) detached the four small wires that appear to be for the touchscreen. They look undamaged. There are two yellow wires and two black wires. I need to reassemble the plug they go into, and wonder if anyone can tell me which wire goes where. Here's a picture of the wires -- in order as they come off the board -- plus the two plug components, plus the board they plug into.
    Click on the image to enlarge it.
    EDIT: I got this answer elsewhere in the LCD/Display forum, so I've included it here in the FAQ:
    Quote Originally Posted by GiODi View Post
    Ha... i did the same thing with my first lilliput. I'm pretty sure they go in the order that you have it there. I don't think it matter too much anyway because it would correct itself in calibration.
    Thanks, GiODi. I'll just hook it up as pictured and test it out.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  3. #93
    sly
    sly is offline
    Mar 2008
    Auto switch feature in some new Lilliput screens
    I think it is very important info and it deserve to be placed here. It seems that some new 2008 lilliputs have auto switch feature, which is very useful when you have for example rear view camera. This feature can be simply activated in menu. But it is not clear why some of new 2008 screens have this feature while the others don't... The subject definitely needs some more investigation. More info can be found here:
    http://www.mp3car.com/vbulletin/lcd-...lilliputs.html
  4. #94
    Nov 2007
    Hey.
    I was working on my CarPC project and I accidentally put pressure on one of the components of the main board of the Lilliput. I need to figure out what to replace it with. Trouble is that I moved in the meantime and I can't find the actual broken piece, but hopefully someone can tell me based on the images below. The missing part was an inductor, the bottom of which is still attached to the board.
    Any info would be appreciated. The part is labeled 2L06.
    It looked like this:
    Anyone know the specs for it or some idea of what to replace it with?
  5. #95
    Jan 2005
    Anyone know where to find gears for the gl701?
    THanks!
  6. #96
    Dec 2006
    BROOKLYN NY
    does any1 have his model 889GL-80NP/C/T
  7. #97
    Nov 2007
    Anyone know what the specs are for the inductor labeled 2L06 on the 619 main board? I posted about this a week ago, both here and in a separate topic and nobody has replied at all. Can someone who has the board please take a close-up pic so I can print it out and take it to some electronic shops? I mean unless of course someone can tell me exactly what the part is and what it's specs are.
  8. #98
    Low Bitrate ContaiN's Avatar
    Sep 2005
    Melbourne VIC, Australia
    I posted this a while back without any answer, so I'll try again.
    Does anyone know how to fix an inverted x axis on the touchscreen? A fellow forumite said by using XP and the touchkit drivers he fixed his problem, but I'm still having the same issue.
    Any help would be AWESOME
  9. #99
    Nov 2007
    Seriously, does anyone not have their display cracked open that they could just post a pic of that component at 2L06? It may be identifyable from that, I need something to go on here to fix my display.
  10. #100
    Constant Bitrate KennyKen's Avatar
    England
    Just thought i would let you all know that i have found a place that stocks the 1.5a fuses inside the lilliputs
    http://cpc.farnell.com/jsp/search/br...equestid=63935
    its the top 1 on this link.
    Prepping for Trax in september
    Re-Building the whole CarPC to upgrade all the software
    Whole new boot build and moulding my screen into the dash...Again
  1. WTB: BROKEN Lilliput 619!
    By masch in forum Classified Archive
    Last Post: 12-14-2004, 03:58 AM
  2. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 06:58 PM
  3. Replies: 1
    Last Post: 04-11-2004, 08:12 AM
  4. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
  5. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
