Finally fixed it.
The 5.0.0.23 drivers were the issue. I downloaded the ones off the Lilliput UK site and they worked without an issue.
Printable View
Pinout for the newer 10-pin DIN plug:
[1][2] [3]
[4][5][6][7]
[8][9][10]
Note: Colors may differ! These colors represent the color coming from my Lilli's controller board (not the VGA/USB plug).
[1] - Yellow - VGA pin 2 (Green)
[2] - Shield - Goes to USB shield
[3] - White - VGA pin 3 (Blue)
[4] - Orange - USB pin 1 (+5V)
[5] - Green - USB pin 2 (D-)
[6] - Brown - USB pin 3 (D+)
[7] - Black - USB pin 4 (GND)
[8] - Blue - VGA pin 13 (H-sync)
[9] - Red - VGA pin 1 (Red)
[10] - Purple - VGA pin 14 (V-sync)
It says on my controller board 619-68521. I am guessing this is a model number? The LCD says Hitachi TX18D11VM1CAA.
I used one of these to make a new VGA cable without the DIN plug:
http://www.btx.com/images/CD%5CCD-HD15MEZB-L.jpg
http://www.btx.com/Categories.aspx?C...5-65bfe2be344f
Some timing info for those trying to get 800X480 on the 7" Lillis:
Mine:
PixelClock, 32143
HorzActive, 800
HorzSync, 32
HorzSyncPulse, 56
HorzBlank, 252
VertActive, 480
VertSync, 3
VertSyncPulse, 7
VertBlank, 20
Flags, 0x20000
Someone else's:
Quote:
Originally Posted by psyrex
bad link to lilli drivers "page not found" for any of the drivers, darn it!
Hey there guys I wanna get this monitor
EBY701-NP/C/T
Found it http://cgi.ebay.com/Lilliput-EBY701-...QQcmdZViewItem
I would like to know if anyone has the measurements for the whole housing
and then just the screen componets. I want to make a custom bezel for it?
i can't find any measurements if it ment my life! It would be awesome if someone could just help me or just push me in the right direction for this information!
-Charles-
Iv'e been searching for awhile I have the 10.4 lilliput.. It DID'nt come with the car adaptor only the AC one.. strange but either way I don't want to run a Inverter 110V. it says 12V 1200mah..output . I understand the wiring to the ignition but is'nt the amps from a car battery alot more than the .06A max input it requires? Im running this off a P4 laptop so no MX/ATX PSU. I plan on using a regulator but what do I need to adjust the amps down or is this not required.. all the forums I see here are targeted toward the ciggerette adaptor cutting and running to the ignition or psu but are they still using the inverter that came on the car plug, and only changing where it's wired too or can it really be wired directly to a 12v-30Amp line without inverter thats on the ciggerette adaptor?
THe front buttons on my BlaXtream TC1000 liliput don't work...:( they used to work now they don't work at all...i need some help plzz..
When i put a cd or dvd in ..the unit autoplays the cd/dvd ..and when i want to change,stop,.. the track/song ..the button doesn't work..
I got my Lilliput screen today and I installed the right drivers for my computer. However, for some reason the screen is not detected by my computers when I open TouchKit. Are there any specific cables I should be using to get the Lilliput to my Mac, or am I just missing something?
digitalww is password protected? cant view the site anymore.. looking for a place to buy a replacement ribbon
http://www.digitalww.com/ needs a user name and password to fuction. Is there anyone with pics of lilliput disassembly I will be puting it into a 2006 f150. Also any install pics or links would be great.
