Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 11 to 20 of 119
Thread: FAQ: Everything you need to know about your Lilliput
  1. #11
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Lilliputs come with 2 different kinds of ribbon cables. Some have this one (pins facing opposite sides): http://digitalww.com/ribbon_cable_oppositeside.htm and this one (pins facing in the same direction): http://digitalww.com/ribbon_cable_sameside.htm
    Armen
    Quote Originally Posted by nthai
    Anyone who ever ordered the ribbon cable from digitalww please help... I pm'ed Armen, called, and checked the website to no available.
    What should I do to order this cable?
  2. #12
    Sep 2002
    ILLINOIS
    LCD Panel Measurements
    [IMG]h**p://www.digitalww.com/images/Lilli_hitachi_LCD_panel_measurements_sml.jpg[/IMG]
  3. #13
    Sep 2002
    ILLINOIS
    Housing measurements
    [IMG]h**p://www.digitalww.com/images/Lilli_housing_measurements_sml.jpg[/IMG]
  4. #14
    Sep 2002
    ILLINOIS
    VGA Controller Measurements
    [IMG]h**p://www.digitalww.com/images/Lilli_VGAController_measurements_sml.jpg[/IMG]
  5. #15
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    I just solved a problem involving my lilliput and I thought I should post it in case it can help someone.
    I installed the lilliput temporarily and connected the power to the cigar lighter. I soon find out that my system that never had a noise before now has a serious alternator whine.
    I cut the wire and connected ( both 12v and ground) to the distribution block were the inverter/ITPS combo are connected. The noise remained.
    Finally I did what I planned from the beginning and didn’t do because of the temporary nature of the installation, cut the egg regulator off and wired the power ( 12v and ground) directly to one of the 12v connectors on the ATX PSU. Cool.. Noise no more...
    My system:
    Distribution block to bat
    ITPS connected to Distribution block and acc and controlling a relay.
    Inverter with the 12v from the Distribution block thru the relay.
    All with common ground on a bolt and less than 30 cm cable.
    AMD board with 90W atx psu, vga and onboard sound, 3.5 HDD and no optical drive.
    Onboard sound connected to aux in, on head unit.
    7" Lilliput.
    Now working smoothly
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  6. #16
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Saw this and it worked to fix my touchscreen. This is not my tip, it's from another user on the boards, but he seems to be inactive for the moment
    Quote Originally Posted by AAVfReak
    Lilliput TouchKit problem solved!
    Greetings,
    I just got my Lilliput 7" touchscreen, and had a problem with the drivers and software that was shipped with it. After spending (wasting) a few hours here on the board, reading posts about how good or bad it is, and how much better the Xenarc screen is, I found a solution that may help a few people.
    The problem: Computer locks up during installation of the TouchKit software, usually after scanning the com ports. It only takes the work of a few minutes to see that a lot of people are having this problem. I hope this helps...
    The solution:
    1. After banging my head on the table trying to uninstall the bad drivers, I finally did a system restore. I tried deleting the INF files and registry entries, but the "Found new hardware" after reboot would not go away. I hate to resort to system restore, but that was my only option at that point.
    2. I downloaded the latest software from eGalax (the authors of the program) at http://www.egalax.com.tw Click on downloads and find your operating system. It seems to me that most people with this problem are using Windows XP.
    3. I installed the software without the hardware connected. After reboot, I connected the hardware, and let windows automatically configure the drivers.
    It all works fine now. I hope this will help some of you that have had a similar problem.
    Have a nice day!
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
  7. #17
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    please add these to the main faqs
    more troubleshooting tips:
    if you have no power going to your lilliput (eg led doesn't even light up)
    either the eggs is screwed up, power it from your power supply; or the smaller ribbon cable is not aligned correctly, it needs to be positioned all the way to the right if the screen is facing up.
    if you have a white screen
    the larger ribbon cable is not in all the way/correctly, for my lilliput with the pins on the same side, the pins are face up on both connectors
    if you broke of the retention clip for the ribbon cable
    use tape/hotglue/toothpick method
    http://www.mp3car.com/vbulletin/show...84&postcount=2
    if the colors are off (eg my screen had a bluish tint to it)
    check the soldered connections on the board, or check to see if the pins on the din connector are bent; check the color settings on the lilliput menu
  8. #18
    Jan 2003
    Ruston, LA
    FAQ Type Responses Only
    Thread cleaned.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #19
    Constant Bitrate blackpacu's Avatar
    Jul 2004
    Setauket
    Please update the driver link:
    The correct link should be
    http://www.egalax.com.tw/support-drivers.htm
    amd 1700, biostar m7ncg 400, hitachi deskstar 120 8mb , 512 pc2700, liliput 7"
    now to put it all together
  10. #20
    Newbie JW™'s Avatar
    Nov 2004
    Valencia, CA
    8" disassembled pics. I'll post measurements up this evening. Click each pic for a larger version.
    Pretty easy to take apart - 4 screws for the back of the case, small tabs in the top to pop out (just like the 7", it sounds like), ribbon cables, etc. The 4-wire connector on the side is for the touchscreen and is a ***** to disconnect. The 2-wire on the other side is a little tough to get to with big fat fingers.
    JW™
    Powered By Sarcasm
    Ranger: Just bought all my replacement goodies
    Expy: Kenwood KDC-X579 from the Ranger; unknown speakers/amp & 10" Earthquake sub, that all came with the truck
  1. WTB: BROKEN Lilliput 619!
    By masch in forum Classified Archive
    Last Post: 12-14-2004, 04:58 AM
  2. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 07:58 PM
  3. Replies: 1
    Last Post: 04-11-2004, 09:12 AM
  4. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
  5. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
