i have mine extended as well (10ft), with no problems. I did put my lilliput on the same ground as the carputer in the trunk, which helped a quality issue that I had.
What resolution are you running at?
hello evryone, i just installed my carpc today and when i turned it on, my lilliput displayed my desktop but the desktop is small and doesnt fill the screen, i tried to center the screen from the LIlliput OSD but it wont let me? HELP!
btw, i extended my VGA cable from the front to my trunk, is this why im getting such poor quality? i know a lot of people have done this but why do they have a better quality coming out?
im runnin 800x600 i think, i only have 2 choices on my control panel display... is there any way i can customize it much better to fix the quality problem? my screen is "wavey" and the picture doesnt fill the whole screen....its more towards the left side of the screen and about an inch or the right side is just black.but
Use the menu to auto-tune the screen.
That should sort it out, provided you are properly grounded.
.//Daren
(Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
MediaCar/CoPilot7/Routis
Hey Bama,Originally Posted by Bama5150
What was the issue that you had? I just hooked up my 8" lilliput for atest run in the car and I get random moving lines on the screen that aren't very obvious but definately there. It doesn't happen when plugged in at home so I'm thinking it's a power issue or something along those lines.
- Kyle
Noise on the signal or poor power management.
.//Daren
