Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
Thread: Displaying reverse camera on a carputer?
  1. #21
    Hayling Island, UK
    What about using a webcam? you can get some good quality ones now.
  2. #22
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    only problem witha webcam or any other type of digital computer input is that you still need some method of triggering the camera action automatically by the reverse lights
    i like eCars method
    thanks for the schematic
    my electronics know how is limited so i must ask this question, what do the little numbers mean?
  3. #23
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    Quote Originally Posted by aoLhaTer
    i like eCars method
    That little numbers indicating each pin where you connect wires. Same numbers are labled on relays. That should help you wire up everything.
  4. #24
    Mar 2003
    Rohnert Park, CA
    i think im even more lost now
    what does the bigger blue box represent?
  5. #25
    Nov 2003
    TN
    On the second schmatic, bottom blue box is a relay which is triggered by reverse light. So camera is to be diplayed when shifted to rear.
    Top blue box is a manual switch.
    It will have three settings, Auto, VGA, VIDEO.
    Did it help?
  6. #26
    Mar 2003
    Rohnert Park, CA
    Im not really understanding what the relay actually is
    Excuse my ignorance
  7. #27
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    The bigger blue box is a SPDT relay. That stands for "Single Pole, Double Throw". Click here if you need to know how a relay works.
    Look for a very small relay. The load (CheeseBox) is very small; probably much less than 1A. In general, the smaller the rated load of the relay, the less current it will need for the trigger (to activate the coil and make the switch). This would be especially important if you have a car that can detect burnt out reverse bulbs. I'm not even sure that you could find a relay that will work without triggering a burnt bulb signal in those cars. By adding the relay, you change the resistance/current in the reverse lamp circuit of the car. A smaller relay will minimize the change, though.
  8. #28
    Nov 2003
    TN
    Excuse my ignorance
    I guess you can think relay as automatic switch when it get some signal.
    In this case, when the relay get power from reverse light (which only turns on when shifted rear), circuit is switched to 87 instead of 87a.
    When power is off, relay is at the 87a position and that makes Cheese box circuit open. When relay gets power, it switche to 87 and that makes cheese box closed.
    FYI, when cheese box is open, VGA is displayed on the monitor and when it is closed VIDEO is displayed.
  9. #29
    Mar 2003
    Rohnert Park, CA
    ah! thanks for the explanation guys
    this would do the trick right
    http://www.radioshack.com/product.as...5Fid=275%2D005
    and the black line triangle at the bottom is ground feed right?
  10. #30
    May 2003
    SE Michigan
    Yeah, but you'd also need a resistor to drop the voltage to the 7-9VDC that relay needs. Look for a 12VDC one.
    If possible, skip Radio Shack. They are the worst. I refuse to buy anything from them, and encourage others to boycott them also.
  1. Auto reverse camera
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 10-10-2008, 03:30 AM
  2. (Div)XBox Carputer (warning: many pics)
    By Richie in forum Show off your project
    Last Post: 09-01-2005, 06:24 PM
  3. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  4. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
  5. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 11:10 AM
