Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 48
Thread: Displaying reverse camera on a carputer?
  1. #31
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    This one is all you need. It's SPST-NO (single pole, single throw - normally open). $2.05
  2. #32
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    thanks
    so whats this thing? ground?
    and what type of fuses?
    AND what pins exactly on the cheese box get connected to the relay?
    again, excuse all the questions, im a n00b when it comes to this stuff
  3. #33
    Constant Bitrate coachreed's Avatar
    May 2004
    Lee's Summit, MO, USA
    The most common SPDT relay, at least in the car audio industry is just a little black cube that is about 1" x 1" x 1" sometimes with a little bracket attached or molded into it for a single screw, and on the bottom, there are five male spade type terminals on it... below is a picture of the bottom which shows the numbers as in the diagrams above...
    I hope that sheds some light on what the numbers are and helps you put it together... This next picture is the same picture but someone has added a diagram of what is going on inside...
    Anyway, I ordered my Cheese Box and should have it soon... WAY before my truck is even running! lol Damn I need to get that thing back on the road so I can resume carputer install...
    TTYL!
    Coach... aka Randy!
  4. #34
    May 2003
    SE Michigan
    Quote Originally Posted by aoLhaTer
    thanks
    That is a ground.
    The fuses may or may not be necessary to protect the wiring. Whether or not you use them depends on your particular setup. It's enough of another subject that I'd suggest starting a new thread if you have questions about where to use them in your setup.
    Here is where to connect your wires to the CheeseBox:
  5. #35
    May 2004
    eCar™-
    Thanks for the info on where to connect into the Cheese Box, which by the way showed up today... only took like 2-3 days to get mine from Baber.com... anyway, now all I need is a running car! lol
    TTYL!
    Coach!
  6. #36
    May 2003
    SE Michigan
    Quote Originally Posted by coachreed
    eCar™-
    TTYL!
    Coach!
    No prob, Coach.
  7. #37
    May 2003
    SE Michigan
    Actually, it was Ryuandwings that started it all (we continued on that subject thru email, until we had it figured out).
    Ryuandwings is the one that deserves the thanks. Especially from me, because he was nice enough to give me a CheeseBox for free! Figuring out how to replace the switch with a relay (also a switch) was no big feat. The initial idea was all Ryu.
    So, thanks again Ryuandwings.
  8. #38
    May 2004
    Well, in that case... Thanks to BOTH of yous! I know I appreciate it... and I'm willing to bet that I'm not the only one. Now if I could just get this motor back into the VX, I could start working on my HUGE amount of fabrication that needs to be done for my carputer. Thanks eCar™ AND Ryuandwings!
    Randy!
  9. #39
    Constant Bitrate slffl's Avatar
    Jan 2004
    Couldn't you do this with a USB webcam, USB relay, and a little programming?
  10. #40
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by slffl
    Yeah, but then you gots to wait till your computer boots to use the webcam.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  1. Auto reverse camera
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 10-10-2008, 03:30 AM
  2. (Div)XBox Carputer (warning: many pics)
    By Richie in forum Show off your project
    Last Post: 09-01-2005, 06:24 PM
  3. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  4. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
  5. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 11:10 AM
