Page 5 of 5 FirstFirst 12345
Results 41 to 48 of 48
Thread: Displaying reverse camera on a carputer?
  1. #41
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    I have used the but not found anything on mod'ing the Lilliput to use the RCA for a reverse camera and keeping the computer on the VGA. I know that the Cheesbox will work, but it is around $70, and *may* add some distortion on the VGA input to the Lilliput.
    Has anybody found a way to do this on the lilly?
  2. #42
    Apr 2003
    Quote Originally Posted by djg
    You can buy the Cheesebox here: http://www.svideo.com/video2vga.html - They delivered mine within a week of ordering.
    I got it hooked up this weekend just as eCar described - I unsoldered the switch off the board and ran a pair of wires out to a relay triggered by the backup lights - works great. The switch on the board is a double pole-double throw but you only need a single pole-single throw to trigger it. The Cheesebox needs a constant 12v to keep the vga passthrough active - I used the Opus +12v to supply it and the camera (a reverse camera off eBay), together they draw about 170 ma. There's about a 3 second delay when it shifts to the camera but the switch back to the vga is instantaneous.
    Dave
    So you connect the 12V to the Cheesebox? I got one of tehse, and the DC power supply it comes with specifies 9V input only.
    Would it work to connect the + to my Opus's 12V and the - to my ATX 3.3V, or would that make something explode?
    Also, in the diagram there's the SPDT at the bottom, then a blue box, then two squiggly fuses. What's the blue box between the fuses and the SPDT?
    --Ed
  3. #43
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    Quote Originally Posted by Sensor
    --Ed
    That's a SPDT relay at the bottom. You could also use a SPST-NO (normally open) relay, as it is the same thing without the unused #87a pin (that provides a NC output). I showed the SPDT because SPST-NO is not too common.
    The other blue box (at the top) is a SPDT 3-position ON/OFF/ON switch (shown in the OFF pos). You use it to select the automatic mode (connected to the reverse lights), camera mode (connected to +12V), or VGA mode (switch is off).
  4. #44
    Low Bitrate Aksor's Avatar
    Mar 2004
    Ottawa, ON
    why don't you get a usb quickcam???
    Laz
  5. #45
    May 2004
    AZ
    Aksor, if that was directed at me, I am looking for something that will be on as soon as I start the truck. The reverse camera makes the most sense when backing out of the driveway or a parking spot - I don't want to wait the time for the CPU to boot and everything to load - it would be simpler to just push the button to change sources. If I have to go with the cheese box I will, but I know it is probably possible to do something similar with the lilliput since it has VGA and RCA inputs, but don't have the skillz to do it
  6. #46
    NEO
    NEO is offline
    Newbie NEO's Avatar
    Oct 2003
    Åmynnet, SWEDEN
    Quote Originally Posted by Supermike
    I was looking for the same. I dont found any post about it
    but if anywone finds anyting so let me now maby Armen have a solution
    Everyting that has a begining has to have a end
  7. #47
    Low Bitrate Bryan Pape's Avatar
    I figure that it would need to provide a single momentary closed state when in reverse to get to analog, and then two momentary closed states when going out of reverse to return to VGA. It's be cool to see this work.
  8. #48
    Deactivated
    Apr 2008
    Hey guys i want to have a reverse cam and a cam for the front of the car. How would i go about connecting theese. The front cam can wait till my carpc is booted but i want to use the reverse cam asap so on something like the cheese box. I live in the UK so is their a cheesebox alternative to this ?
  1. Auto reverse camera
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 10-10-2008, 02:30 AM
  2. (Div)XBox Carputer (warning: many pics)
    By Richie in forum Show off your project
    Last Post: 09-01-2005, 05:24 PM
  3. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 08:57 PM
  4. Replies: 9
    Last Post: 10-23-2004, 02:25 AM
  5. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 10:10 AM
