Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 95
Thread: Anti-Glare solution found?
  1. #61
    Constant Bitrate StationRocket's Avatar
    Sep 2003
    Rochester, NY
    Quote Originally Posted by ddogg_777
    You've been very helpful. Do you know where to get adhesives and conductive coatings?
    three places off the top of my head
    Adhesives research
    POC
    intellecoat
    (spelling?)
  2. #62
    Sep 2003
    Rochester, NY
    oh yea try edmund scientific as well they have all sorts of stuff
  3. #63
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    hmmm - great info on the polarization, stationrocket. Thanks!
    now get back to work!
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
  4. #64
    Newbie Vicci's Avatar
    Santa Barbara
    Wow, I've gotta say, SR sure knows his stuff. Refraction matching (in my experience) is next to impossible unless you're the manufacturer and have the ACTUAL technical data on your materials. Nearly all of the touch substrates are polycarbonate, but the quality control on them is very poor, and I'm guessing the index of refraction actually varies noticably from one side of the screen to the other.
    Furthermore, in my research of touchscreens, I found a side-on view of a touchscreen, which shows that they actually rely on an air pocket between the two layers, such that ANY AG covering would likely not combat the internal refractive nature of the TS.
    Now, this is only true of what are known as "Resistive" and "Capacative" touch screens. If you get really fancy and decide to place an "Acoustic Wave" touch panel on your screen, you won't find any such air pockets.
    The spec sheet that Sun-Tai sent me for one of their units (which, btw, only cost $25!) show this. Look at the tiny space between the glass and film. Look again that the adhesive only goes around the edge, not covering the whole screen (as would be needed to keep light from passing through the additional medium of air...again).
    I decided to attach the spec sheet. Enjoy. It's big.
    There's nothing you can't do, so don't be discouraged just because no one else's done it.
  5. #65
    Sep 2003
    Rochester, NY
    hmmm, more air gaps :-(
    This info make me even more certain that the right surface is the inside of your windows.....
    Vicci,
    What are you guys gonna do with the fold out unit you're working on. any luck finding a touchpannel with a good coating already laminated to it?
    The SID confrence that's in Seattle next week is the best trade show for finding components and parts for display systems. If you guys have the means you should really get someone out there to walk the floor. I remember last year there were lots of different people offering this sort of thing. I was going but i had to cancel my trip last week because things are going a little crazy around here.
  6. #66
    Sep 2003
    Rochester, NY
    the right surfact to coat that is
  7. #67
    Jun 2002
    Malaysia
    stationrocket, is the SunTai touchscreen good? I mean will it combat glare? The 1.5+/-0.5 is that too big a gap?
    From what I understand from your post, the reflective glare is due to the air gap between the two layers aye?
  8. #68
    Mar 2004
    Chicago, Il
    guys, ive received the film and cut it to size and tried it over the TS and unfortunately, it doesnt really make much of a difference.... I think it reduces the glare by maybe 5%, if that. Everything just looks cloudy.
    I decided to remove the TS completely just for comparisons sake and i was amazed as to how much better the screen looks without it. Nice and crisp. I dont know what else to do about the daytime glare, so for right now, im just gona keep the TS off and hope that someone can find a better solution.
  9. #69
    Aug 2003
    thats sucks.
  10. #70
    Sep 2003
    Rochester, NY
    --masch--
    sorry I'm not familiar with that particular one. But any touchscreen will make the glare worse not better. any air gap no matter how thin will hurt the same amount.
    The reflection (glare) will happen at the interface between any two materials with different indexes. The bigger the index diff the more light that's reflected.
  1. Battery Isolator solution?
    By breimann in forum Power Supplies
    Last Post: 04-17-2005, 06:45 PM
  2. Anti Glare coatin
    By navig8r in forum LCD/Display
    Last Post: 05-15-2004, 07:28 PM
  3. Replies: 1
    Last Post: 03-04-2004, 07:02 AM
  4. Data logging solution for non OBD2 cars...
    By doig in forum General Hardware Discussion
    Last Post: 11-06-2003, 11:29 AM
  5. Anti glare plastic sheet?
    By jose in forum LCD/Display
    Last Post: 03-19-2003, 06:50 AM
