My lili does that too, but it only occurs like 1/2 of the time. the internal ROM has some prob? Would powering the lili with car battery instead of cigar lighter solve the problem?Originally Posted by CdRsKuLL
just wondering if anyone has the same problems.. it seems to zero brightness and contrast..
Specs for my previous carputer:
Car: 03 Maxima SE
Carputer Hardware: AMD Athlon XP1800+, Full size MB, 512MB RAM, 20G HDD, FX5900, SB Live
Screen: Lilliput 7" Touch
Install pics: http://members.shaw.ca/hermanao/carputer.html
Same here, I get that problem often as well.
If you power the lilly through a car battery, how do you turn it off? (I mean, completely)
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
Look This -> Display brightness
Will be help me!
Regards
Oliver
http://picasso.zoffi.net
I have a similar problem so I hooked it up to the 12 volts from the computer power supply. Are there any problems with that? It seems to be just as bright and functional as the ac wall plug.
- Kyle
That's how I have mine and I don't think there is a problem with this method at all (as long as the power is still going through the egg shaped adapter thing). It's probably the best way to do it anyhow, since it's a clean 12V and it's only supplied when the computer is on (ie. screen is only powered when you need it).Originally Posted by the_dude
I'm actually bypassing the egged shaped thing. I assume it's just designed to keep around 12 volts from a car battery. A regulator? I'm not positive but it seems that when I hook it up the screen is dimmer, like the egg isn't doing that good of a job. I figure the 12 volts from the computer has got to be pretty solid power supply. It's hard to A\B from my house to car for brightness but when I hooked up the dc egg unit to a 12 volt battery in my house and then the wall, the egg unit is definately dimmer. Maybe the batter is funky, I don't know(It reads 12.5 volts with no load).
Maybe I'll try the egg thing hooked with the computer power supply and without.
- Kyle
this post wasnt really about the brightness of the lilliput, more the settings in the menu sometimes changing for no reason
yeah, but like most topics they shift to something else, hence the other posts only somewhat related.
See, now it's changed to be about posts going off topic!Originally Posted by the_dude
