Results 1 to 10 of 15
Thread: Need replacement connector for Lilliput
    Feb 2004
    I have damaged the connector on the back of the LCD. Does anyone know where I can get a replacement. I just need the beige colored piece that pivots up and down to hold the ribbon cable in place.
    Thanks!
    Feb 2004
    The toothpick solution
    What do you think of this solution?
    I found that just gluing the broken piece didn't exert enough downward pressure on the cable. I tried 4 different glues: Loctite SuperGlue Gel being the best because it was thick and didn't run down into the connector and it sets within 30 seconds (because I couldn't find a good way to safely clamp it while the other glues set in 20-60 minutes).
    However, in the end, a wooden toothpick worked perfectly and I didn't use any glue at all. The duck tape doesn't do anything, I just didn't want to remove it after finding something that works.
    May 2004
    Hi
    I've just fouind myself in a similar position so I'll give your method a try.
    I also need a replacement ribbon cable - it's the same one that's shown in your pic, the one that goes from the back of the panel to a circuit board.
    Any ideas where I could get hold of one?
    JB
    Newbie mportobello's Avatar
    Jan 2004
    Calgary, Canada
    This solution isn't perfect. Anyone know where I can get a replacement connector (see pictures in first post).
    When I put any pressure on the right side of the plastic case, the screen goes blank or appears scrambled.
    Replacement cables are available for $3 from www.digitalww.com
    1997 Toyota Celica
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    I have the exact same problem, does anyone know where to purchase broken latch?
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
    May 2004
    TW
    I have the same problem, but I can find source here(Taiwan). I'm planning to replace the beige cover with new one only. Otherwise, it's also not so difficult to replace whole connector.
    Anyway, I just order this parts today. Once it's done, I'll see what I can have help to you guys.
    Dominic Lu
    Feb 2004
    Thanks dominiclu! Let us know how it works.
    I am going to try ordering a couple of different connectors from www.digikey.com and see if any of them fit.
    Feb 2004
    Digi-Key Part: HFR40CT-ND appears to be very similar. I've got it here and I will try in the Lilliput when I mount the screen in the car.
    I've also orderd HFJ40CT-ND (close, may work) and WM5684CT-ND (definitely won't work).
    Tampa, Florida
    Has anyone found a replacement for the header and ribbon cable?
    AMD Athlon XP 2000
    Viking 256MB DDR
    Seagate 120GB
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Seems a lot of people have this problem. Any tips on avoiding breaking it? I'll be ordering a lilliput soon, and don't want to destroy it when I take it apart...
  1. looking for replacement remote for 7" lilliput
    By lesko in forum LCD/Display
    Last Post: 03-17-2007, 06:47 PM
  2. Replacement usb wire (earthmate)
    By Cyber_Drone in forum GPS
    Last Post: 04-26-2004, 01:38 PM
  3. Compaq Armada M700 screen replacement?
    By jol in forum LCD/Display
    Last Post: 10-15-2003, 05:52 PM
  4. 5" replacement bulb?
    By nyconx in forum LCD/Display
    Last Post: 04-11-2001, 02:15 PM
  5. [Sproggy PSU] T6 replacement
    By Shaper in forum General Hardware Discussion
    Last Post: 03-21-2001, 07:54 AM
