bump
hey,
I just got done installing a matrox millenium II for my psone lcd mod Works great better than the rage on intel i856 I was trying to use. I got everything working great but 2 things.
1. I get full hight but have to ajust to to be in the right area (too low)
2. I can't get full waith from the screen.
I'm using powerstrip v.2.51 if that helps. any idea of how to fix this?
Mage
Down load the latest version of powerstrip and try it out.
This is what I have on Matrix Mystics 200.
Winamp5 1-1/2 size
GPS: Delorme Street Atlass.
I am using PowerStrip 3.49 (I think)
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Thanks for the replay I'm now using 3.49 and I get the same resalt ( but now after upgrading for free to paid I can't do custom res!) is the Matrix Mystics 200 same as the millenium II? what's your settings can't seem to get the pix clock below 30 too but I did get it to veiw save the with!
thanks again
Mage
I am using freeware/trial version of PowerStrip. I am not sure if the Mystics 200 is the same as Millenium 2. But if you can do Custom resolution, it will work.
How did you mod the cable? 270 Ohm resistor trick or a TTL Sync circuit? Check some of the PSOne mod threads for the TTL Sync circuit I posted. That the one I used.
I'm runing stright sodared wire no sync circuits or resistors via one of the post I went over both mpro and starfox's? for the last 3 months! I'll look up the ttl sync circuit mabe that will help But I dont think it's a sync problem thanks for the help!
Mage
WooT! I got it to do full with now! but it does this roll thing it just rolles could it be becuse the vid card will not alow it to go below 30hz? or something else?
thanks for all the help!
Mage
PS: I'm not using power strip that's was what was messing it up!
looks like nobody has taken off the clear plastic on their screen either
so you just wired it staight through and it worked? nice! and how are you using the screen without power strip? i haven't had any luck here
I made a driver for the psone screen. it didn't work on anyother card I had So mabe only the millenium II can do it? dont know untell I get it from scrolling wich I belive is a refresh rate problem? or pixel clock problem.
Mage
mage
i already have a compatible video card(TNT) and the official sony lcd.
i only need some cabling to get this mod working , correct?
a standard VGA cable and some sodering?
