Hi Brettster,Originally Posted by Brettster
I have the exact same setup as you without problems. Are you sure you use the 12V wire? (yes, otherwise the Xenarc probably wouldn't run at all).
I any event I use the Opus with stand-by power off, that way it shuts off all power to the mobo and just uses very little power to 'listen' to the ACC line. This only works with hibernate or shut-down. There are two jumpers on the Opus to control this.
Kris from Opus said powering the Xenarc in this way would work, provided there is no excess of peripherals taking up power (USB stuff).
try to hibernate.
Michael
LinkBack URL
About LinkBacks
